Thread: Need an ECU - z20net
    brum
    Default Need an ECU - z20net
    I think my ECU is faulty on my signum 04 plate 2.0 turbo
    replaced the EGT sensor and the code says still open circuit
    checked voltages and they are fine from ecu
    reference temps are -6441c and tis says replace ECU
    checked resistance on ecu loom at it is near enough zero
    even put a 2.2k ohm resistor on end of loom and checked resistance from ecu connector and it what it should be
    there is no resistance figures on the egt sensor however tis does not ask you to check for resistance on the sensor
    so therefore need an ecu to check before i go out and get it replaced if possible
    i have opcom so i can program the ecu in if need be
    WGAF#5
    there was an ecu on ebay last week? ...is it still there ?
    yep - there are two
    http://shop.ebay.co.uk/?_from=R40&_t...All-Categories
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by ephidor View Post
    Is that you Mike?
    brum
    yah m8
    Regular Member signumturbo04's Avatar
    SCOTLAND
    is the car in limp mode or anythin as my car says the same for egt on opcom but no eml or running problems :s
    brum
    yeh emissions light with dtc code p0546
    in 2004 they took out the EGT sensor
  1. z20net
    By sri-100 in forum Engine & Drivetrain
    Last Post: 6th November 2012, 22:05
  2. z20net mpg
    By james23 in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2012, 11:30
  3. Z20net
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2011, 09:56
  4. Anyone with a Z20NET...(2.0T)
    By n_hudson in forum Engine & Drivetrain
    Last Post: 12th March 2009, 12:35
z20net egt sensor
z20net limp mode
ecu z20net
vectra z20net ecu number
z20net update ecu
