Results 1 to 3 of 3
Thread: misfire on gas help with fault codes
    Aug 2010
    leeds
    Default misfire on gas help with fault codes
    hi the car is mis firing on gas...
    1-2000 rpm....
    codes are
    P1565
    P0301
    P0302
    P0420
    P0170
    Pls can anbody advise me on wat to do or who to got to get it sorted pls thanks base wakefield
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    P0301
    Cylinder 1 Misfire Detected.
    P0302
    Cylinder 2 Misfire Detected.
    P0170 Fuel Trim Malfunction (Bank 1).
    P0420 Catalyst System Efficiency Below Threshold (Bank 1).
    P1565 Speed Control Command Switch Out of Range High.
    Aug 2010
    leeds
    car runs fine on fuel just gas...........
    anything i need to check to reslove was googling and saying maf..
    thermostat
  1. Feels like a misfire but no fault codes!
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 9th December 2012, 02:03
  2. misfire and crankshaft error codes
    By shadow.warrior in forum Engine & Drivetrain
    Last Post: 26th July 2010, 00:54
  3. Fault codes?
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2010, 21:06
  4. 2.2 Direct misfire codes- help please!
    By mostynmiller in forum Engine & Drivetrain
    Last Post: 27th February 2009, 20:31
  5. Fault/Error code - misfire on cyl 1, 3 & 5
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2007, 20:44
