Thread: signum -alternator belt replacement
    Oct 2009
    wakefield
    Default signum -alternator belt replacement
    Help - can any body tell me how to replace alternator belt on 2005 signum 20T . and belt route - ie: belt snapped and dropped off.
    Many thanks Mike A
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Regular Member Jezzy's Avatar
    S.E
    I think you need to remove the driver's side wheel arch liner to gain access to it.
    Oct 2009
    wakefield
    many thanks for your help this is excellent i assume the tensioner is spring loaded
    again thanks as you know you can see nothing from top.
    Mike a
    Jun 2009
    South Coast
    yes it is spring loaded.. i replaced this belt earlier this year, its tricky one.. you need somebody to push up onthe tensioner from below, then somebody over the top feeding the belt on, if the loop the string around the belt to use to pull it over the pulleys it will save your fingers and your temper.. I believe some guys even managed to do it on their own but not sure if they took the tensioner off first. Inthe side of the tension their is a square hole for using maybe a half inch socket adapter to get some leverage on it (you can see it in the pic).
    Jun 2009
    South Coast
    btw the belt is otherwise known as the Multi V belt
    Oct 2009
    wakefield
    thanks for all the advise - have put new belt on with my son took about 30mins all in.
    Mike A
  1. New alternator and belt
    By Mark-R in forum Engine & Drivetrain
    Last Post: 14th September 2012, 17:20
  2. 2.0T Alternator replacement
    By neilbroad in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2011, 11:35
  3. Alternator Belt! HELP A.S.A.P
    By rwellfair in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2010, 07:43
  4. Signum 2.0t alternator belt
    By turbohaggis in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2009, 11:37
  5. dti alternator belt help
    By rorycarz in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2008, 23:09
signum car fan belt
https:www.vectra-c.comforumshowthread.php118658-signum-alternator-belt-replacement
vectra c alternator belt change
changing alternator on vauxhall vectra c 2.0t
signum 2.0 turbo alternator remove
how to change alternator on vauxhall vectra
vectra turbo al
vectra 2.0t belt tool
signum belt change
signum alternator belt snapped
Vauxhall signum alternator belt
how to change vectra c 3.2 alternator belt
signum serpertine belt diagram
how to change alternator on vauxhall signum
