Thread: 1.9 CDTI 150 - Smoking/Sounding abit pants
    Wolverhampton
    Default 1.9 CDTI 150 - Smoking/Sounding abit pants
    Im having some trouble,
    Its a 56 Vec C 150 CDTI, done about 126k, fully serviced.
    Only recently, once its warm and ive done a few miles in it, Ill have spells where lots of smoke will pile out from under the car toward the front, which let me to beleieve that the exhaust has gone, because it can sound abit 'blowy' at times, but other times it will run fine.
    Im not sure if this is pointing toward the EGR valve which is a common fault, but Im not really loosing any power when It has these spells. Might feel a little lumpy now and again but nothing major.
    Iv had it looked over quick at a local garage and he couldnt find anything wrong with it right away, but then again, it wasnt showing symptoms when I took it round there (typical!)
    Anyone have any idea of where its going wrong?
    Regular Member mozzer99's Avatar
    bristol
    Sounds like the DPF (diesel particulate filter) is regenerating and leaking in some way (or burning off oil that has leaked onto it).
    I'd get it on a ramp and do a manual regeneration to see what is causing the smoke. (manual regen by using op-com or tech2).
    PRESTON
    Check the flex pipe on both the exhaust and on the exhaust manifold where it leads to the egr cooler (right hand side of manifold, held on with two bolts) Both theses have been known to split.
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Quote Originally Posted by barney490 View Post
    I had to change my flex pipe on my 1.9cdti 8v smoke was coming from the front.
    Steve
    Get the car on the ramps with the car running put your hand next to the flex pipe you will feel the air coming out if it has split.
  1. 1.9 CDTi 120 Seems abit sluggish....
    By Vectra Adz in forum Engine & Drivetrain
    Last Post: 12th November 2012, 17:14
  2. V6 CDTI SMOKING...... but just once!?
    By BigWilko in forum Y & Z30DT Specific
    Last Post: 30th April 2012, 22:29
  3. CDTi 150 - Abit laggy?
    By MadOnVaux! in forum Engine & Drivetrain
    Last Post: 29th April 2012, 16:14
  4. cdti sounding rough when cold
    By leeky1 in forum Engine & Drivetrain
    Last Post: 16th March 2011, 15:43
  5. 1.9 150 cdti owners, abit of help please
    By shake in forum Diesel Engine related
    Last Post: 6th December 2006, 08:13
