Thread: how do you clean throttle body on 1.9cdti?
    Aug 2009
    Ascot
    Default how do you clean throttle body on 1.9cdti?
    Cleaned my EGR now wondering if i should clean the throttle body , but ensure where it is???
    Nick
    Sodding Typical on Sea
    The throttle body isn't such an issue to clean as it is basically a tube with a butterfly flap in the middle and some petrol / solvent will wipe it clean.
    It is once you remove the three 5mm allan bolts and access the fluted section at the nose of the inlet manifold that you can make significant improvments as those channel flutes fill and clog with oil/carbon sludge from the crankcase breather / egr.
    This bares out what some of us believe is a significant aid to longevity gained from allowing the crankcase to vent to atmos, as this removes the "glue" from the intake system that sludges up with the carbon from the egr and strangles the engine.
    Aug 2009
    Ascot
    Is the throttle attached to the EGR valve?
    Nick
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    No!, The EGR is fitted to the inlet manifold & the Throttle body assembly is also fitted to the inlet manifold, RED SQUARE= EGR, PINK CIRCLE=THROTTLE BODY, YELLOW CIRCLE=BOOST SENSOR.
    http://www.vectra-c.com/forum/showthread.php?t=109248
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Quote Originally Posted by the-wizard View Post
    No!, The EGR is fitted to the inlet manifold & the Throttle body assembly is also fitted to the inlet manifold, The EGR is fitted to the rear of the manifold & the throttle body is fitted to the right hand side of the manifold.
    Thats true for the 150's.
    On the 120's the EGR connects to the throttle valve with a 90degree metal corrugated pipe. The EGR is not connected directly to the inlet manifold. Only the throttle valve is.
    The Throttle Valve and the EGR are on the top right corner of the engine on both the 120 and 150.
  1. Clean throttle. Body
    By daddy5times in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2013, 20:17
  2. egr / throttle body clean at 45K
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2011, 16:23
  3. 2.2 dti clean throttle body
    By tomo610 in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 13:36
  4. DTI Throttle Body Clean
    By si_hoss in forum Engine & Drivetrain
    Last Post: 7th July 2010, 13:37
vectra c throttle body cleaning
vectra cdti 150 throttle body
how do you clean the throttle body on a vectra c
vauxhall vectra 1.9 cdti throttle body
vectra diesel throttle body
throttle body in vectra
cleaning vectra c throttle body
vectra c cdti throttle body cleaning
vauxhall vectra 1.9 cdti throttle body cleaning
https:www.vectra-c.comforumshowthread.php118633-how-do-you-clean-throttle-body-on-1-9cdti
vectra c throttle issues
vauxhall zafira throttle body cleaning
advantages of cleaning an astra h 1.9 cdti design 150 throttle body
how to clean throttle body vectra
2008 vectra 1.9 cdti throttle actuator repair
how to remove throtle body on a vauxhall insignia
vauxhall vectra c cdti sri throttle body clean
vauxhall astra 1.9cdti throttle body problems
1.9 cdti inlet manifold cleaning
throttle body 1.9 cdti
astra 1.9 throttle body
vectra cdti 120 inlet manifold clean
