Thread: 22dti engine failure
    Oct 2009
    gateshead
    Default 22dti engine failure
    need a bit help guys ,the turbo gave up and forced the engine oil into the cylinders causing the car to run flat out and wouldnt switch off,managed to stall it,its either blew the bottom end shells or bent a conrod its running but fooked so need a new engine,does the y22dtr engine from vectra b fit,obviously i no pipes ,pump etc are different but does a bare block vectra b engine fit,even a x20dth will do for now if it will run,just need to get it back on road as cheaply as poss,,thanks in advance for any advice,dave
    Regular Member benny's Avatar
    Feb 2006
    dudley
    did you fit a new turbo to find out it still run rough ?...
    Oct 2009
    gateshead
    yes mate fitted new turbo dropped the oil etc and fooked
    Feb 2006
    dudley
    ok ..so it is fooked ....yeah you can swop any vauxhall 2.2 engine aslong as you use you pump and injectors in it .... if you use a fronty or omega lump you8 will need to swop the sump ..but any front wheel drive will be a straight swop ..all you need todo is swop you injectors and pump as a matched set ....
    Oct 2009
    gateshead
    champion mate thanks alot.so a 20dti will fit also just be bit underpowerd,thanks again mate your a star
    Feb 2006
    dudley
    you might get smoke problems with a 2.0 due to the pump and ijectors beeing jigged for a 2.2 but it might be worth a try if you cant find a good 2.2
    Oct 2009
    gateshead
    thanks again mate...
  1. Timing belt failure/knackered engine???
    By 123rado in forum Engine & Drivetrain
    Last Post: 15th December 2012, 18:35
  2. Bad mot day engine/emissions light failure
    By monty2000 in forum Troubleshooting
    Last Post: 4th September 2012, 20:02
  3. 1.8 VVT engine failure
    By mucklestone in forum Engine & Drivetrain
    Last Post: 6th December 2009, 12:11
  4. Test GTS 22DTI
    By AVestphal in forum Signature & Avatar Testing
    Last Post: 24th February 2008, 20:59
  5. Cruise control failure, Engine light
    By stevedee3 in forum Engine & Drivetrain
    Last Post: 13th November 2005, 11:00
