Results 1 to 10 of 26
Thread: Fault Codes Found
    Kent
    Default Fault Codes Found
    Well plugged my new fault code reader on tonight and identified these faults:
    OP-COM 081016 - PC based diagnostic tool
    Please add your workshop
    name in the settings window
    OP-COM - CAN Communicaton Window> 2004|Vectra-C / Signum|Engine|Z 19 DT
    Read Info...
    Identifier: 0x0711
    VIN: W0L0ZCF3541079931
    Hardware number:81011449
    Motor type: Z19DT
    Part Number:55189630
    Software version number: MNPMS120_S
    Hardware manufacturer number: 0281011449
    Hardware key number: S001002172
    System description: BOSCH0100
    Type approval number: B04016
    Alpha code: LM
    Hardware manufacturer system name: EDC16
    Total number of fault codes: 3
    P0703 - Brake Switch Circuit Malfunction
    (04) - Not present
    P0380 - Glow Device General Error
    (08) - Not present
    P1125 - Throttle Actuator Feedback Circuit Malfunction
    (08) - Not present
    So we know the faults but how do I rectify them?
    Edit
    Ive searched the individual codes and in order:
    P0703 Torque Converter/Brake Switch B Circuit Malfunction
    P0380 Glow Plug/Heater Circuit "A" Malfunction
    P1125 Throttle position sensor intermittent
    So would I be correct in assuming I need a new throttle pedal and sensor?
    Kent
    This is what Im considering buying but is the sensor built in or would I be better off buying a new part
    Regular Member wright879's Avatar
    Chippenham
    Trim : Life
    Engine : CDTI 120
    I thought that "not present" meant it was an old fault that just needs clearing?
    Steve
    Kent
    I did clear the faults and I think its the same 3 faults which were there when the garage scanned it and cleared it, I just bought the scanner as I couldnt keep taking the **** and getting free scans.
    Forgot to add the link above:
    http://cgi.ebay.co.uk/VECTRA-C-ELECT...9#ht_564wt_911
    Sep 2010
    Hartlepool
    Fattony - Has your car been having a slight hesitation while you have been driving it?
    Mine does this, and this morning I used cruise control instead of keeping my foot on the gas and the problem didn't occur which leads me to think that I may have the same Throttle Position Sensor Intermittent problem.
    I used the same conditions - 70mph in 6th gear - but the speed was regulated by the CC instead of pedal and no problem.
    Kent
    Could anyone expand on this fault code as I believe its whats causing my hesitation and I changed the throttle pedal with no success - fault is still there.
    Richy yes I have the same problem but doesnt seem to be there with cc on, mines just over 100k miles how about yours?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    As I replied on your other thread m8, ask the garage to check the connection at the throttle pedal and ECU.
    Gazza4
    jilava
    Quote Originally Posted by fattony View Post
    Maybe you need to clean/change the throttle body.
    Kent
    yes sorry I shouldnt relate both threads, where abouts is the throttle body and what should it be cleaned with?
    its a 1.9cdti 120
    PRESTON
    Surely if it was the throttle body the fault would be there using either the pedal or cruise. As previously stated, it sounds more like fly by wire connection between the pedal and ecu.
    Follow the big turbo hose on the right hand side of the engine to where it connects to the engine, that is the throttle body. Probably best to remove it from the engine and clean with carb cleaner and a small brush.
  1. fault codes
    By Fraz in forum Engine & Drivetrain
    Last Post: 4th December 2011, 21:40
  2. codes found
    By bembo449 in forum Engine & Drivetrain
    Last Post: 11th May 2011, 05:54
  3. Fault codes?
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2010, 21:06
  4. Vectra 2.6 Diagnostic codes P0170 & P0173 Found
    By hairyone in forum Vectra C / Signum Troubleshooting
    Last Post: 1st August 2009, 11:21
  5. another fault i found out
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2006, 22:35
vectra c throttle body linked to cruise control fault
vectra cdti 120 p1125 www.vectra-c.com
