Results 1 to 10 of 23
Thread: 3.2 GSI A Few Issues Help Needed Please
    Sep 2010
    SUFFOLK
    Unhappy 3.2 GSI A Few Issues Help Needed Please
    Hi All,
    AM new to the site just picked up my 02 plate 3.2 GSI. As soon as i have got it some isses have appeared. I am begining to think its a pup, however i did get it for the right money paid 2700 and its done 50k FSH, 1 owner etc.
    Garage have replaced two wheel bearings and the rocker cover gaskets before we picked it up.
    Also the car was sold to us "As Taken In" does this mean we have no warranty or come back !!??.
    If anyone could shed any light on these points i would be really greatfull.
    Are any of them common issues ?
    1. The front section of the exhaust has gone on the Flexi Pipe ( Hopefully Garage are sorting that tomorrow)
    2. When she is idling the engine isnt silky smooth like it was when we went to view the car, it is as if its not firing correctly on one cylinder, you can feel it lumpy as you sit in it.
    3. I dont know if this is normal or not but when i turn the ignition on the "Engine Electronics" warning light comes on until the engine is started then it goes off is this normal ??.
    4.When she is idling and you rev her for a split second there is a squeek that sounds like a pulley or belt slipping.
    5.Tha garage have serviced for us before we got it, when we viewed it the engine was smooth and silent, however now it seems to be a little tapetty, so i am assuming they have used cheapo oil that isnt getting into the lash asdjusters when its cold.
    6. Finally when pulling away in 1st or second there seems to be a dull whining noise that has now appeared.
    Many thanks in advance
    Mileage : 000
    2) might be the air control valve in need of a clean.
    3) you have a stored fault still. It might go away after 20-30 starts of the car. Reading the code will tell you the fault Try this method worked on my 3.2 Engine.
    http://www.vectra-c.com/forum/showthread.php?t=81742
    Regular Member Jezzy's Avatar
    S.E
    The lumpy idle could a fault with the DIS pack - how does it drive at normal speeds?
    Devon
    Quote Originally Posted by gibsonk View Post
    Hi All,
    1) When you say they are sorting it bear in mind the only way to sort it properly is to either replace the whole front exhaust sectionor to weld a new
    flexi joint in. Anything else they do will be temporary fix and won't last very long at all!
    2) Rough idling is a commen problem with the GSI but if it more than this and is actually misfiring with no engine management lights on I would try changing the spark plugs (especially as the rocker cover gaskets were changed - oil could have coated the plugs). This is not a starightforward job on the GSI and could have therefore have been skipped.
    4) Could be the auxillary belt slipping or a problem with the alternator.
    5) Try changing the oil for a 5w 40 grade - I use it and my engine has no tappety noise whatsoever.
    Oh and if there is no evidence of the cambelt being changed recently get it done (along with the water pump) immediately, and don't forget to check the common Vectra problems (broken springs, leaky rear shocks, worn arb bushes, front drop links & rear upper suspension arms.
    Sep 2010
    SUFFOLK
    Everything is good at speed, no problems at all. DIS pack i am assuming is the distributer pack ??
    Sep 2010
    SUFFOLK
    Quote Originally Posted by dae36 View Post
    The cam belt was changed by VX stealer at 44k its marked up in the log book. I would hope they are replacing the front section but wouldnt be surprised if they patch it up
    If needs be i will change the plugs myself, cant be that hard i had my FTO cambelt, intake manifold and cam carriers of to sort some issues,
    Is there any workshop manuals on her for reference ?? couldnt find any with the search.
    My biggest concern is the noise when pulling away, hope this isnt the gearbox gone i have seen a few people have had problems with them.
    Regular Member v6boy's Avatar
    PRESTON
    Trim : GSI
    Mine is like this, sometimes with aircon on when engine idles slightly faster it is less noticable.
    Also does this, will probably start to do it when you start the car too, like a quick chirping noise
    Regular Member david.aka.judas's Avatar
    Suffolk
    mine gives a quick chirping noise when you start, any idea what it is?
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Quote Originally Posted by david.aka.judas View Post
    Could it be a small blue tit nesting in your airbox David.
    Suffolk
    Quote Originally Posted by John C S View Post
    grrrr..... I want to say something funny in return but I'm smiling too much.......hahaha.
    you, you..............!
  1. SRi Turbo running issues - help needed
    By johnsastra16v in forum Engine & Drivetrain
    Last Post: 22nd April 2012, 14:56
  2. SRi Turbo running issues - help needed
    Last Post: 4th March 2012, 17:15
  3. Help needed! dtuk box issues
    By swifty_53 in forum Diesel Engine related
    Last Post: 24th February 2011, 19:40
  4. New Car a few issues Help Needed :(
    By stevelee in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2009, 00:28
How to change rocker cover gaskets on a vectra 3.2gsi 04 plate
