Results 1 to 3 of 3
Thread: a few issues with my gsi, can you help....
    Regular Member david.aka.judas's Avatar
    Suffolk
    Default a few issues with my gsi, can you help....
    1. leaking coolant - I can smell it but I can't see it, I lose about an inch over 2 weeks, it smells when the engine is hot.
    2. had the cam belt changed, the car sounded absolutely great, 2 days later its developed a loud squeeking noise, it does go away when the engine hot and the sound frequency changes with the revs.
    3. the c/c doesn't always work, sometime it does sometimes it doesn't. sometimes it cuts off when you press the speed up button.
    4. the air recirc flap isn't stuck but when it rains, it steams up quite bad, it does need a new filter could it be that.
    5. after 7 years and 50k miles, it sometimes feels sloppy handling, what can I change to improve the handling?
    6. a couple of lines in the rear window dont demist, can it be fixed?
    thanks if you can help.
    Slough
    92 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    Quote Originally Posted by david.aka.judas View Post
    time to sell it then David and get a vxr khalid
    the vectra has gone , but not far away so ill still see it form time to time
    1) you have a leak. Could be anywhere but you will see signs if you look. The oil cooler seals are a weak spot.
    2) did you change the aux belt as well as the cambelt or did you try to save a few quid? There is an indicator on the tensioner for this.
    3) both my signum and vectra needed new panels as eventually the fan speed button did nothing when pressed. They are over £300 new from the dealers although I found one brand new for £80.
    4) change the filter?
    5) new bushes. Ideal time to lower and update it.
    6) new window really but you can get repair kits although they arn't much good IMO. Wait for it to smash and call your insurance company.
  1. EGR Issues
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 30th June 2012, 11:51
  2. GID issues
    By kensbey in forum Electrical & ICE (including SatNav)
    Last Post: 11th May 2011, 17:46
  3. Issues!
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2011, 01:13
  4. Would I have any issues with...
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2008, 19:07
  5. mp3 issues with cd 70
    By jeff_g in forum Electrical & ICE (including SatNav)
    Last Post: 6th June 2008, 22:27
