Thread: Ignition replacement advice please
    Regular Member bighammerfan's Avatar
    hillingdon
    Default Ignition replacement advice please
    Hi. I had my ignition drilled out as the steering lock was stuck on (probably not necessary but it was in the garage with a broken timing chain and they decided to drill it). Can anyone give me advice on how i go about renewing...will it need programming etc. Many thanks
    hillingdon
    bump
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    In honesty, I don't think people understand the question. It is too vague.
    I only speak personally, as I certainly don't understand what you are asking.
    Exactly what bit are you in need of replacing?
    hillingdon
    the barrel has been drilled out. if i buy a new one with a new key will it work as soon as its fitted or will the key need coding
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If you are just replacing the actual key barrel, then I don't think it will need reprogramming, if you re-use your old immobiliser pick up ring from around it.
  1. Advice on the dreaded DMF replacement :(
    By Splatharri in forum Engine & Drivetrain
    Last Post: 11th January 2012, 13:17
  2. Ignition barrel replacement video ?
    By bighammerfan in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2010, 15:01
  3. Ignition Switch replacement
    By magpie27 in forum Electrical & ICE (including SatNav)
    Last Post: 16th April 2009, 17:13
  4. Replacement parts advice
    By hutch85 in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2009, 21:10
  5. Replacement Exhaust Advice
    By 24vElite in forum Petrol Engine related
    Last Post: 8th June 2007, 14:35
