Thread: Brake Disc's
    Regular Member slipperysam1984's Avatar
    Apr 2009
    Bournemouth
    Default Brake Disc's
    Hi,
    I need to replace the rear brakes on my siggy soon, and i wanted to know how do you know if the disc needs replacing as well.
    I don't want to put pads on and find that the disc is screwed.
    So do you replace the disc's after so many pad changes?
    thanks in advance
    Sam
    My rear discs were changed at the first pad change as they were quite worn down.
    If you buy the parts from Vauxhall then it's cheaper to buy a brake disc/pad kit than it is to buy the discs and pads separately. Can also apply to other sellers as well. Thought I'd mention it in case you bought the pads on their own then discovered later that you also need discs as well.
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    The discs need replacing if they are very heavily scored and/or rusty. You will know if they are heavily worn by the lip on the edge of the disc caused by the pad wearing the metal of the disc away. There's no set point to replace discs, one look at them should tell you if they are serviceable or not.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi SS
    minimum thickness for rear discs (ventilated) 18mm
    minimum thickness for rear discs (solid) 10mm
    Regular Member dcm23251981's Avatar
    Jul 2011
    burnley
    hi guys had front and rear discs and pads fitted back in august and over the last coupler of days there has been a loud squealing noice from the f o s after inspection there is 2 rings not heavily scored but what can be the problem help ??????
    Jul 2011
    burnley
    Default vectra c 54 plate scored disc
    had new discs and pads fitted back in august and a couple of days ago the front o s started squealing after inspection there is 2 rings in the centre but not heavily scored what could it be help
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sound's like the common problem of the heatshield behind the disc touching the disc
    Jul 2009
    Brighton
    Quote Originally Posted by dcm23251981 View Post
    You could have a small stone stuck between the disc and pad. Happened to me on my old golf. Just remove the pad and inspect them.
    Jul 2009
    Brighton
    Quote Originally Posted by slipperysam1984 View Post
    Hi,
    thanks in advance
    Sam
    As mentioned above, but also look at the hub part of the disc, it should say the min thickness. Mine are solid and read MIN 10mm.
  1. Brake pads & Disc's
    By tris_hill in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd June 2011, 15:45
  2. What size disc's?
    By mishima in forum Suspension, Wheels & Brakes
    Last Post: 9th May 2009, 18:31
  3. What disc's do you have?
    By Leemarksmith in forum Handling & Braking
    Last Post: 27th June 2008, 22:00
  4. 314 disc's and pads
    By chrisgettings in forum Handling & Braking
    Last Post: 23rd January 2008, 18:26
  5. How much for rear brake disc's and pads!?!?!?!
    By carl bear in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2007, 21:02
