Results 1 to 10 of 15
Thread: V6 CDTi reading error codes
    Apr 2009
    St Albans
    Default V6 CDTi reading error codes
    Chaps,
    I'm getting the spanner light coming on randomly, around once a week.
    Switching ignition off clears it.
    I spotted the 'pedal trick' on the forum to read the error code , but doesn't seem to do anything. Can someone confirm if it is supposed to work with this engine.
    Would just like some idea of what the fault is before taking it to the dealer
    Ta.
    The engine warning light has to be on for the pedal trick to work, as I found out by testing with the MAF sensor disconnected
    Are you sure it is the engine warning light, and not the service light?
    The service light will briefly appear when there are less than 1000 miles to next service
    Once you are below 500 miles it stays on all the time
    It looks like a can with a spanner through it
    Apr 2009
    St Albans
    It's definitely the EML light. Car with Spanner through the middle of it.
    As the light goes away when the Ignition is switched off, not sure how I can do the pedal thing while the Light is present?
    Do I switch the Ignition off, and try the pedal trick immediately before it resets?
    Just to be sure I'm talking about this 'trick'
    http://www.vectra-c.com/forum/showthread.php?t=81742
    Ta
    Tony
    If the EML warning is coming on all the time, then it should be stored
    If the EML warning stops coming on, then it is typically deleted after the ignition has been restarted several times
    Therefore, switch the engine on, and get the EML warning light to appear
    Then proceed to the pedal test
    However, not all cars do it, mine doesn't either
    I disconnected the MAF sensor which reports a fault code
    However the pedal test returned nothing
    Ironically on the next visit to the dealership they advised there was an old fault code stored which they had cleared
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The warning light (either MIL or Car with spanner) do not have to be illuminated for the process to return fault codes.
    It only works for some cars, but mine currently has a P1565 Stored (cruise control), but neither of the warning are on or have been on at any time. The car is also operating correctly - including cruise control.
    If it doesn't work on your car, buying a cheap code reader may be cheaper than going to the dealer.....
    EVERYWHERE
    Quote Originally Posted by Ste View Post
    U480 off ebay will suffice.
    Apr 2009
    St Albans
    Bought a U480 off Ebay as suggested , but it doesn't read any error codes.
    Plugged in , when EML light showing and Scan shows 'No Codes'
    Any ideas?
    It's a 2003 model, pre facelift, should the codes be able to be read?
    Apr 2009
    St Albans
    Guess it'll have to go to a dealer/specialist to be checked out.
    Can anyone recommend somewhere which has experience of this Engine anywhere in Herts/Bed/North London area.
    Lost confidence in the usual place that services it after they completely cocked up the Cam Belt replacement @ the last service.
    EVERYWHERE
    Quote Originally Posted by averdigi View Post
    Any ideas?
    U480 works perfectly well on my 2004 half canbus V6 diesel.
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    I have a U480 also, works on my facelift V6 diesel, some of the codes clear when the ignition is turned off, the best way to check is to stop the engine but do not remove the key and then plug the reaser in.
    I recently had an EGR issue and the code was never stored if I removed the keys, try that, it may help.
  1. 3.2 error codes help please
    By gibsonk in forum Engine & Drivetrain
    Last Post: 28th January 2012, 13:03
  2. error codes
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 29th June 2010, 13:27
  3. Reading fault codes on 1.9cdti
    By clightowler in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2010, 22:20
  4. CDC 2006 reading Disc error
    By tshort2007 in forum Electrical & ICE (including SatNav)
    Last Post: 14th December 2009, 01:17
  5. Help With error CODES...!!??
    By sheiky in forum Engine & Drivetrain
    Last Post: 26th July 2007, 11:30
https:www.vectra-c.comforumshowthread.php118559-V6-CDTi-reading-error-codes
