Thread: Help please on intercooler
    leeds
    Default Help please on intercooler
    Hi guys im due to change my intercooler this weekend to a fmic as mines goosed i was hoping for some help on here as to what size diameter the hoses are on the car to the factory intercooler as the fmic ive ordered is a 65mm inlet and outlet, ive got a siggy 1.9 cdti 120,any help will be grateful thanks.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    how many liters is the front mount one ? .... the original is a large unit .if the new one is smaller it might give you some problems .... sorry i have no idea on hose size but i do use the inlet hose on me landrover intake and they do go small when the clip is tightened ....
    leeds
    im not sure i think the litres is slight smaller but shud it give me problems as the original is restricted with being stuck between rad and air con unit and the fmic will be right at the front. what problems can happen if there is restricted airflow?
    thanks for the post
    Feb 2006
    dudley
    well to be fair if it is close on it may not give ya any ...i was thinking you had a small thin style one and not a beefyer one ...if it does give you problems they might be higher preshure one side of the turbo and low the other wich may give boost codes but if it does you knopw what it is ..lol...
  1. intercooler?
    By justin32 in forum Engine & Drivetrain
    Last Post: 19th January 2013, 17:09
  2. Intercooler
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2012, 12:36
  3. Standard intercooler v front mount intercooler
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 29th June 2011, 09:58
  4. Intercooler
    By user999998 in forum Engine & Drivetrain
    Last Post: 16th May 2008, 11:02
