Thread: 1.9 CDTi Auto Box Sticking
    Regular Member s-owen4's Avatar
    Aug 2010
    Consett
    Default 1.9 CDTi Auto Box Sticking
    Hi Folks
    The auto box on my 1.9cdti (150) seems to be sticking in second gear, the engine revs build then the car clunks into third, this only happens between second and third. I only have 66,000 on the clock. Any Idea's??????
    EVERYWHERE
    Check that oil level is correct first.........and that it's the right colour.
    Aug 2010
    Consett
    Thanks diesel dog
    Where do I find the level indicator??????
    Full Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    If it's AF40, I suggest you go to a repair shop for an oil change. It's suppose to be changed every 50.000 miles. It won't come out more than 2.8-3 litres and for best results you should do this at least 2 times.
    All the work it's done from under the car. By work I mean getting the oil out and putting it in. Putting it in it's done trough the same hole.
    Jan 2008
    Wiltshire
    Default I have the identical problem
    Hi there. I have a 1.9 cdti Siggy with an identical auto box problem 2nd into 3rd. It has 72,000 miles on the clock.
    Did a simple oil change work for you or is it more complex? I would welcome learning from your experience before approaching a garage with my debot card ready!
    Cheers,
    Andy
    Oct 2009
    Bilbao&Madrid
    Vehicle : Opel Signum
    Trim : Cosmo
    Engine : 3.0 CDTI Z30DT
    I was suffering the same issues some weeks ago, and yes, the oil change has cured the problem (so far). The clunking also happened when changing between 4-5 or 5-6, by the way.
    Anyway, an Opel dealer (in Spain) has changed the AF40 oil in my '06 Signum (it was approaching the 60,000 miles mark), and the thing goes like that:
    - AW-1 oil at 14,95 euro/litre (x3)
    - O-ring and something else at 3 euro, more or less
    - 1,20 hours to change the oil
    - 1,30 hours to check, program, adjust, whatever
    - + VAT
    So 50 euro in materials, 150 euro for the work (+VAT).
    I don't know how this translates to UK prices, but hopefully it will give you an idea of the relative costs (materials/work hours) and the size of the hole in your wallet.
  1. 1.9 CDTi rear caliper sticking
    By Tennants in forum Suspension, Wheels & Brakes
    Last Post: 14th October 2012, 13:06
  2. VECTRA AUTO STICKING IN 5th GEAR
    By cosjon in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2009, 20:38
  3. Brakes seem to be sticking-SRI CDTI
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 1st January 2009, 20:12
  4. Sticking Auto Box
    By Gersh in forum Engine & Drivetrain
    Last Post: 26th December 2008, 10:47
  5. Brakes seem to be sticking-SRI CDTI
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2008, 19:22
