Thread: revs up and down the stalled
    May 2008
    RAMSGATE
    Default revs up and down the stalled
    its a 2.2 petrol sri, was fine all day then all of sudden the revs went up and down a few times then stalled and now jumps a bit on idle!!! coil pack????
    Jan 2010
    glasgow
    egr valve prob fella there is a how to on here i think
    Regular Member benny's Avatar
    Feb 2006
    dudley
    did it rattle ?....is it a z22se or yh ?
    May 2008
    RAMSGATE
    its a se and the egr valve has been removed. cheers
    May 2008
    RAMSGATE
    also its a bit tappy on tick over...
    Feb 2006
    dudley
    check the chain aint slipped ...
    May 2008
    RAMSGATE
    any other idea
    Regular Member Sambor's Avatar
    Elgin
    I have the same.Timing chain has been change,EGR clean.Can the coil pack?!But to buy just to check is not so cheap.
    Regular Member slinky270306's Avatar
    Aug 2010
    Devizes
    I had similar issue, stutter when accelerating and then at times it would jump revs goin up and down then after few seconds be fine again.
    Eventually ecu came up on dash as i knew it was mis firing. AA came out and reported misfire on cylinder 4.
    Booked into VX, they added fuel cleaner, changed plugs found update for the EGR valve and £115ish later seems to be all sorted.
    May 2008
    RAMSGATE
    my egr has been removed
  1. 3k revs and thats it.....
    By johnaw in forum Engine & Drivetrain
    Last Post: 11th January 2012, 18:44
  2. All revs no go!
    By Princess D in forum Engine & Drivetrain
    Last Post: 2nd November 2010, 00:11
  3. Car went in big puddled and stalled and wouldnt start for ages
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 18th July 2009, 00:14
  4. vec c stalled can anyone advise me
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2009, 23:19
