Results 1 to 10 of 15
Thread: Replaced n/s front ABS sensor
    Jan 2008
    llanddewi
    Unhappy Replaced n/s front ABS sensor
    My ABS and traction control lights came up , on checking all wheels I found the front n/s lead from the ABS sensor to the connector on the bottom of the spring missing, it looks as though it's been torn away.
    I have replaced with a new hub ( the sensor cable is moulded in).
    The How2 for brake disc replacement was very helpful.
    Have tried disconnecting the battery for over an hour but the ABS/Traction control light are still on, is there anything else I can try?
    I have road tested the car but need to find some loose gravel to check out the ABS.
    Darlington
    I think you will need to get the exact faultcode read from the car,
    This will indicate exactly what is wrong.
    or have the existing fault cleared from the memory to see if the car logs a new one. which in turn will indiacte where the problem is.
    Jan 2008
    llanddewi
    Thanks for the reply, today I had the fault codes cleared but it came back immediatley as front n/s abs sensor high volts, low volts and then a couple of other things all appertaining to the abs sensor.
    The garage I used had another vehicle they were working on where they had just fitted a new sensor and it to was still showing abs fault!!!!!
    My old sit up and beg side valve Ford Anglia was never like this.
    If you put ameter across the ABS sensor what sort of reading should you get.
    Darlington
    Hi
    Yes my old mk1 Astra never had any fancy electronics to keep me safe - never did me any harm either.
    Im sorry but im afraid I dont know more I cant tell you what volts you should be getting as I wouldnt know where to start
    Oct 2007
    nottingham
    did you fit a genuine vauxhall hub as cheap after market ones have in the past given abs light problems.
    tommy
    Jan 2008
    llanddewi
    Fitted a FAG 93186388 which is the same as the one fitted by a vauxhall dealer 2.5 years ago.
    Do you know if there are any electrical connectors behind the n/s front wheel arch liner?
    and are there any more that I should check?
    Thanks Brian
    Oct 2007
    nottingham
    Quote Originally Posted by llanddewi View Post
    fitted a fag 93186388 which is the same as the one fitted by a vauxhall dealer 2.5 years ago.
    And are there any more that i should check?
    Thanks brian
    sorry brian do not know anything about connectors.
    Tommy
    Nottinghamshire
    I don't think there are any connectors behind the wheelarches - just the ones inside them behind the suspension struts where the wire from the main loom connects to the wire from the ABS sensor in the hub.
    Inspect the wiring to see if it is in good condition and ensure the connectors in the plug under the wheelarch are clean and dry.
    Also, can you get a 'known good' ABS sensor and connect that? If that clears the fault then it's definitely a faulty ABS sensor in the new hub.
    There is a way of testing the ABS sensors in the wheel hubs by connecting an oscilloscope to the pins in the wiring connector and checking that it produces exactly the right pulses of voltage as the wheel is turned. Any deviation from the specification will cause an error.
    As a previous poster mentioned, there have been a few posts on here of new non-genuine hubs causing ABS problems and having to be replaced with genuine ones.
    Jan 2008
    llanddewi
    Thanks for the info , not sure how I am going to get a good known hub, I will not be able to use the one on the off side, 1. they are a pig to get off after they have corroded a bit. 2. If I did use the off side one that would still show a fault as one would still be missing.
    Brian
    Nottinghamshire
    Brian
    Can you swap the hub you bought for another one on the basis that it appears to be faulty? Or perhaps you could return it if you can get your money back and then buy a genuine one? However...
    At this point, I would consider getting the fault codes read if you haven't had this done already because it's hard to fix a fault when you don't know exactly what the fault is. Wheel speed sensor faults are specific to each wheel and the descriptions are quite specific as well so they should help to pinpoint the fault.
  1. Replaced front offside wheel bearing, but ABS connector does not fit
    By sharp114 in forum Suspension, Wheels & Brakes
    Last Post: 21st July 2012, 21:42
  2. replaced Rad without removal of front bumper
    By dcm23251981 in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2012, 14:25
  3. Replaced a front hub yesterday
    By sheepish in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2011, 21:21
  4. Front Air bag sensor (NS)
    By deskpro in forum Bodywork & Interior
    Last Post: 10th April 2011, 11:42
  5. Front shocks replaced
    By Ian T in forum Handling & Braking
    Last Post: 28th July 2008, 11:48
https:www.vectra-c.comforumshowthread.php118538-Replaced-n-s-front-ABS-sensor
vectra c abs sensor
vectra c abs sensor location
vectra c front wheel speed sensor
vectra c auto speed sensor location
vectra c abs light on
abs cable for vauxhall 2007
vectra c abs connectorwhich side is the abs sensor located on vauhxhall corsa 2007vauxhall vectra c wheel speed sensorvectra c vss locationhow to clean abs sensor vectra chow to fit abs sensot vauxhall corsa 2007vauxhall vectra c abs sensorhow to remove opel vectra c abs sensorvectra c sensor absvectra c removing abs plugns sensor hubastra 2009 sxi how to remove front abs sensorremoving and replacing abs sensor on a vauxhall vectra 2008how to test wheel speed sensor on 2007 vauxhall vectrawheel sensors on a vectra cwhat type of wheel speed sensor is on a vectra cvectra c front wheel speed sensorsvauxhall omega front abs sensor
