Results 1 to 10 of 11
Thread: water in header tank bubbling....why ?
    Regular Member manimal's Avatar
    Grimsby uk
    Default water in header tank bubbling....why ?
    Hi
    I have a Vectra C 2002(52) 1800 petrol
    For a long time now i have had a problem with the water in the header tank.
    When i turn the engine off, the water starts bubbling rapidly like a cauldron.
    The temperature gauge reads correctly,no signs of overheating.
    Last week i had to replace the head due to a snapped cam belt.At the same time i had a water pump fitted & a crank sensor, but still the water is doing the same.I am puzzled as to why this is happening.
    Anyone shed some light on this please ?
    Regular Member lanky659's Avatar
    Jul 2010
    Abingdon, Oxfordshire
    it could be the cap on the header tank that is causing this if you losing no water.
    Grimsby uk
    Thanks for the reply but i've already changed the cap
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    May be in idea to have a sniff test done in the header tank just in case the heads not bee torqued down correctly and youve got a leak.
    Grimsby uk
    I'll do that,but it had this problem before i had another head put on :-(
    Devon
    Coolant in a sealed system cannot boil. If yours is boiling you definitely have a leak somewhere in the system!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    As above!,& this sounds like head gasket!, or a cracked head!!.
    Grimsby uk
    i've just had a look & i think my epansion bottle has a small leak.Would this cause it ?
    gwent
    Hello it's gases from the engine between the head gasket going back to the header tank it also could do damage to the rad so if I was you I would get the head gasket done plus check the head as well
    11 Post(s)
    Quote Originally Posted by manimal View Post
    Rather than guessing, why not just get the system pressure tested?
  1. water returning to header tank
    By vectra-man in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2013, 23:43
  2. coolant bubbling from expansion tank 1.8LS 112k
    By TonyTangles in forum Vectra C / Signum Troubleshooting
    Last Post: 7th March 2011, 00:42
  3. header tank cap??
    By vanquis1979 in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2011, 23:15
  4. header tank cap
    By animal22 in forum Engine & Drivetrain
    Last Post: 6th March 2009, 14:52
  5. Header tank.
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2008, 21:41
vectra c 1.8 coolant boiling
engine coolant bubbling vectra
