Results 1 to 2 of 2
Thread: how much torque
    Aug 2009
    Havant
    Default how much torque
    How much torque can the gearbox on my 6-speed CDTi[150] take?
    I think I can get nearly 260BHP out of it and about 415 lb/ft
    thats with a CRD-T box (or remap) and a specialist LPG kit.
    I know I'll kill the DMF before the gear box but I'm planning on getting an old fashioned flywheel (not dual mass) made for it. Or just welding the 2 bits together...
    EVERYWHERE
    Gearbox is rated at 295lbft (400Nm) maximum torque capacity handling. This is the maximum figure and not a nominal figure, hence the reason why the maximum torque of any Vectra (or any other vehicle that uses the F40 gearbox: Vectra 3.0 V6 diesel, Alfa 2.4 JTD) is bang on a max of 295lbft.
    If you fit a solid flywheel (or make one!) that will only make matters worse for the gearbox (DMF is transmissions 'shock absorber'). You'll also probably need an uprated clutch if you plan on anything much above the gearboxes rated capacity.
    Note: There will be those that say that they've put 400 pounds of torque through it, no problem. But you know the facts now, so the choice is yours.
  1. torque pro
    By andy_richmond in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2013, 12:17
  2. 3.2 V6 torque
    By Ginge7289 in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2011, 19:58
  3. Thats some serious torque!!!
    By BigWilko in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2010, 15:40
  4. torque
    Last Post: 14th October 2009, 19:48
  5. bhp & Torque
    By Gambler in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2009, 18:03
