Results 1 to 10 of 19
Thread: Coolant line..is this normal?
    Regular Member Maurice's Avatar
    Nutterden (D)
    Default Coolant line..is this normal?
    When arriving home this morning , I saw something odd about the coolant returnline. It seems to have some sort of bumb on it. Is this normal, or does it needs replacement?
    Can't take it off right now , it's to hot.Maybe , if not ok , it's the reason why i loose coolant/built up pressure.
    Thanks allready!
    Uploaded with ImageShack.us
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I had problems with that exact coolant line on my old 3.0CDTi. There was absolutely no coolant flowing back into the expansion bottle!!! Replaced that and all was fine
    Nutterden (D)
    So , it's indeed a problem ,or could get one. There is some flow , but not as much as the other. I'll go to Opel tomorrow to get me a new one.
    Thanks for the advice!
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    On my car the problematic coolant line was connected to the top though...not to the bottom like in your case. Looks like someone switched yours.
    Nutterden (D)
    Eek
    Quote Originally Posted by Celes View Post
    Could that give any problem?
    I've changed the line for a "new" one , this time same size fuel line.
    Seems to be the same material with reinforcement.
    I've cut open the old one and found a huge restriction inside the line.
    Have made a picture of it. After replacement there is like a 200% more coolant flow . Could that solve my pressure problem? Hope so
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I've no idea what that thing is but that was inside my coolant line too. I believe all V6's have that...
    Nutterden (D)
    Maybe it is a form of reinforcement to prefent it for bending?Don't know. It does create a lot of pressure at the engineside , seen by the bump that it has created . I'll take it for a drive after dinner , maybe the coolant stays in now ...
    By the way , should I change it's position? (Bottom to top change)
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Nah, leave it
    Nutterden (D)
    Nah, leave it
    I'll take your word for it
    Let you know if there are any problems after the drive this evening!
    Thanks!
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Should make no difference if you swap them as both take coolant back to the bottle Report back if that solved your issues
    What's the mileage on your car?
  1. cdti 150 coolant temps, is this normal?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 12:53
  2. New to all this. Changing 2 line display for 3 line one.
    By CBak109 in forum Electrical & ICE (including SatNav)
    Last Post: 21st September 2012, 23:03
  3. CD30 Facelift 2 line to three line display??
    By mucklestone in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2011, 22:29
  4. coolant line flow direction?
    By jtg in forum Engine & Drivetrain
    Last Post: 9th July 2008, 20:10
  5. 'normal' coolant temp
    By Mike57 in forum Engine & Drivetrain
    Last Post: 9th July 2007, 20:27
