Results 1 to 10 of 15
Thread: Car with Spanner Warning
    Sep 2010
    Sheffield
    Default Car with Spanner Warning
    I apologise if im posting this wrong but ive only had my signum 3 days and i have a warning light.
    When its cold and i turn on the ignition i get a car with a spanner through it come on, then when i start it, its a little rough and exhaust is a bit smokey. After about ten seconds after setting of its fine, the light goes out and its smooth again.
    Been told the fuel filter but i was wondering if anyone has had the same problem
    Dan
    Jan 2010
    wirral
    you need to have the code read then someone on here will be able to point you in the right direction, can't see it being the fuel filter to be honest but until you have a DTC its just guess work!!
    Regular Member Dazzy2006's Avatar
    Notts
    if its a diesel more than likely you have a duff glowplug
    Jan 2010
    wirral
    I've had the glow plug problem but the car/spanner stayed lit up for about a mile or so of driving, and there was no smoke. Having said that, 3 out of 4 of my plugs were knackered so that may explain the light staying lit for longer. But it really is guess work without a code!!
    Sep 2010
    Sheffield
    how do i find the code, vaux want £70 for the pleasure of driving it on their property
    Quote Originally Posted by SignumDan View Post
    Try the pedal trick - mentioned in the how2 section.
    Jan 2010
    wirral
    yes try the pedal trick.
    But it did not work on my 56 plate, i think it only works on the older vectras, ie.non-canbus.
    Or try a backstreet garage, or buy a code reader or similar
    Sep 2010
    Sheffield
    Its a signum and the pedal trick isnt working, think i might have to stump up the cash at the garage
    Notts
    Try yell.com for a local diagnostics firm, they usually cost around £30ish or get a fault code reader off ebay
    Sep 2010
    Sheffield
    could anyone suggest a fault code reader, there is a gunson one at £40 dont know how good the make is
  1. Spanner Warning Light
    By TAL in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 18:13
  2. Warning light (car with spanner)
    By KeefyB in forum Engine & Drivetrain
    Last Post: 20th September 2010, 11:58
  3. car and spanner warning light
    By paul515 in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2009, 01:49
  4. spanner through oil can warning ??
    By derby4life in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2008, 05:41
  5. Car with spanner warning light
    By DennisTheMenace in forum Engine & Drivetrain
    Last Post: 23rd March 2007, 07:47
