Thread: Intermittent hunting
    Regular Member manimal's Avatar
    Grimsby uk
    Default Intermittent hunting
    Hi
    I have a 2002 (52) Vectra C 1800 petrol.
    Last week i had a secondhand cylinder head fitted after my cam belt snapped,(Ouch!).
    Engine runs spot on whilst driving, but on idle it hunts intermittently.
    I have cleaned the throttle valve unit & put injector cleaner through it & also unblocked a breather pipe from the throttle unit to the cylinder head, but still no joy.
    Anyone had similar fault or knows how to fix it please ?
    Thanx in advance.
    EVERYWHERE
    Off the top of my head.....dodgy crankshaft position sensor (check connection). Could be loads of things though. Any codes?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    My engine occasionally done this on idle usually followed by cutting out, and also had a flat spot in the rev range too.
    I'm getting the throttle sensor/pedal unit changed tomorrow - hoping that fixes the problems.
    Gazza4
    Grimsby uk
    I had a crank sensor fitted at the same time,I'll get it checked,thanx
    Grimsby uk
    O.K. I have a code ......P1565.
    Can anyone shed some light on this please
    Grimsby uk
    Found out what this code is......Speed Control Command Switch Out of Range High.
    Where the hell is this switch & what do i do about it?
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    id be interested in knowing the outcome of this, had a similar problem since having the cam belt changed. havent checked for codes yet though.
    Grimsby uk
    I went to the Vauxhall dealer today, they did'nt know where to locate this switch, they said it could be behind the throttle pedal.Then....kerching ! it clicked, my cruise control on the indicator arm has stopped working properly.The accelerator (up) doesn't work anymore,decelerator (down) works.P1565 is the code for this switch out of range (high) fault. P1566 is the code for this switch out of range (low) fault.So i put 2&2 together & i think this switch is the one on the indicator arm.So i'm thinking of replacing it.Any thoughts on this before i do ?
  1. Job hunting
    By Critch in forum General Chat
    Last Post: 10th March 2012, 13:59
  2. Fw Help ban fox hunting.
    By bobssignum in forum Comedy & Humour
    Last Post: 21st November 2010, 18:26
  3. 2.0 T hunting on idle
    By stephen g in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2010, 20:33
  4. Fox Hunting
    By fingers66 in forum Comedy & Humour
    Last Post: 14th April 2009, 20:56
  5. Fox Hunting
    By Dodger in forum Comedy & Humour
    Last Post: 16th December 2007, 00:47
