Thread: help
    Sep 2010
    sheffield
    Default help
    my vectra which is 2003 2.0d wont go into any gears when started but will go into gears when the cars turned of what could it be is it the clutch, i just bought the car a week ago
    Liverpool
    yep, sound like a dud clutch unfortunalty
    Sep 2010
    sheffield
    Default aaah
    does that mean a whole new clutch wat abouts the flywheel
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Can you see any leaks under the car? What is the clutch pedal doing? Have you made sure the thing is topped up with brake fluid? As yhe clutch runs off the same resivour if not the gearbox is gonna have to come out Whilst the gearbox is out I'd replace everything for peace of mind bud the clutch slave cylinder and the dmf if it has one save you money in the long run
