Results 1 to 10 of 23
Thread: z20net compresion test figures
    Regular Member larrysSRI's Avatar
    Nov 2009
    south wales
    Default z20net compresion test figures
    I have a compression tester and want to know What figures are normal to expect?
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by larrysSRI View Post
    The 'N' in Z20NET indicates a compression ratio of between between 9 and 9:5:1.
    Nov 2009
    south wales
    Quote Originally Posted by john_k_sri View Post
    Im after the result I would expect on the tester dial.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    do you have a problem with your engine ..?.....is the guage in psi or bar ? ...
    Regular Member DaveW555's Avatar
    Cannock
    Just do the test and write down the figures and post them for me to have a butchers at. It should be obvious as you do each cylinder if there's a problem but make sure you take all the plugs out rather than one at a time as it can be misleading doing it one at a time. I'd expect to see the gauge go to at least 12 bar (170 ish psi).
    Nov 2009
    south wales
    Quote Originally Posted by DaveW555 View Post
    Before I do the test Is this the correct way to do it.
    Spark plug out, tester in, coil lead disconnected, foot throttle then turn over.
    Feb 2006
    dudley
    not test fig given by vx ...but they say the max difference between cylinders should not exceed 100kpa ..1bar ....14psi .... what fault do you have in the engine ?
    Nov 2009
    south wales
    Quote Originally Posted by benny View Post
    Smoking when decelerating which Is smelling oily and also entering the cabin at low speeds.
    Feb 2006
    dudley
    turbo ...is knackered ...
    Nov 2009
    south wales
    Been told if the turbo is knackered then it will smoke all the time?
    Anyway, im gonna do the compression test this morning so that should give a bit more of an idea whats wrong.
    Fingers crossed it is the turbo and not the rings or valves etc!
  1. OBC figures...
    By JJ0063 in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2012, 19:16
  2. Z20NET SW version - test mode
    By buggy in forum Petrol Engine related
    Last Post: 18th March 2011, 13:20
  3. MPG What figures do you really want.?
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2011, 20:26
  4. 2.2 DTI Figures
    By Genterz in forum Diesel Engine related
    Last Post: 2nd November 2008, 01:32
  5. r r figures
    By jay-z in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2007, 12:15
z20net compression
compresion test
compression test z20net
