The real issue with the DMF rattling is a wrecked starter motor/solenoid.
Gazza4
Gazza4
the dmf noise is diff mate, put ur clutch in half way and listen for a noise while at idle.
if yours has been doing it for ages mate that gives me alot of relief tbh
Well 40k of rattling so far have a mate with a skoda taxi that rattled for nigh on 100k before the clutch finally went
THAT rattle could be the bracket that holds the exhaust down pipe,just down a little after the manifold union with the exhaust pipe.Mine had the same symptoms and it was a straight forward welding job.(Took it to NTS and had an oil and filter change at the same time for £45).Give them a ring if you find it is the problem,they're very reasonable.When I say NTS,I don't mean NATIONAL TYRES!!!!!FELIXX
