Results 1 to 10 of 11
Thread: heated seat problems
    Sep 2010
    bolton
    Default heated seat problems
    hi guys, iv just gone to use my heated seats today for the 1st time and the light comes on for a min or so then starts to flash? same on the passenger seat as well? then i turned of and re tried it and it didnt light up then it did and just the same on the passenger side to..strange one! anyonw know if i can fix it or is it into the dealers and get my wallet out?
    Full Member Big Sig's Avatar
    Have you checked the fuses? They will be listed in the manual and are located in the rear fuse box - passenger side boot cubbyhole.
    Sep 2010
    bolton
    i will check mate.but i thought if the fuse had gone it would be totaly dead and not light up at all
    Quote Originally Posted by parky1 View Post
    No, because the fuse is for the heater pad, not the switch.
    Sep 2010
    bolton
    ah i see. ill check soon as rain stops..thaks mate much appreciated and fingers crossed. ill let you know
    Its probably not that as they are fused seperately. Front left and front right but always start with the simple things.
    Sep 2010
    bolton
    just checked...fuses ok
    If you have access to a multimeter then you can check continuity through the heat pads from the same fuse holders in the rear box. If you haven't then check the connectors under the seats as they may come apart - although this should also bring on the air bag lights.
    Sep 2010
    bolton
    ok ill try thanks
    Sep 2010
    bolton
    well iv just been trying this today and the fues was blown 15a so i replaced it and it blew again straight away, so i put a 30a in and it blew that as well
  1. Replies: 42
    Last Post: 1st April 2012, 16:03
  2. Heated seat
    By Dunc in forum Insignia car chat
    Last Post: 6th February 2012, 21:17
  3. Airbag light and heated seat problems
    By V5LED in forum Bodywork & Interior
    Last Post: 11th March 2011, 20:58
  4. heated seat switches? also electric seat adjust questions?
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 11:48
  5. Heated seat help!
    By lukesignum in forum Bodywork & Interior
    Last Post: 22nd January 2010, 18:13
heated seats dead including switches vectra c
