Results 1 to 10 of 11
Thread: Anyone had issues with warning lights after LED conversion?
    Liverpool
    Default Anyone had issues with warning lights after LED conversion?
    As the title states!
    Have driven over 30'miles and car and spanner light is still on, tried dissconnecting battery. Took clocks out again to double check no problems and now airbag light is on also!
    Help!!!
    Full Member Big Sig's Avatar
    On a 150? and error light?? Never
    Have you looked for the pedal method on here for reading the error codes? It may work it may not. For the airbag light, do you or did anyone move the front seats or clean under them? They may have disturbed the plugs under the seats.
    Liverpool
    Oooooo pull that knife out my back haha!
    I haven't tried that yet, airbag light has now gone out on way to work but car and spanner is still there
    Im hoping that it's just a change in voltage or me connecting/dissconnecting whilst ignition on that's thrown the error up, fingers crossed it clears itself
    I take it everything works as it should? If it does you need the error/fault codes
    Liverpool
    Yep everything is working fine!
    Tempted to just take the led out lol
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Have you put the led in the right way mate? Before I put any of my LEDs is I bench tested them all, I found a few duds so it saved me time in the long run. Even a stray bit of solder could cause the lights SMD's to misfire as it were.
    Liverpool
    Yes I double checked today, LEDs only work one way don't they, and all are illuminating so I am presuming I've done it right
    Vehicle : SRi
    Mileage : 137000
    I cant remember now but are there any 4 pole smd's in the dash kit?
    Liverpool
    yes, 4 x plcc4's for the odometer, all seem to be working fine, and placed in the same way as the ones removed
    West Yorkshire
    The spanner light is for engine faults only.
    Find the error codes and post them up
  1. Issues with steering along with ABS and TC lights
    By reeces555 in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2012, 12:49
  2. Front Lights issues on 03 vectra 2.2 elegance
    By Nokia1 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th May 2012, 00:28
  3. Boot lock /warning issues
    By nikroc in forum Suspension, Wheels & Brakes
    Last Post: 20th June 2011, 21:05
  4. LED conversion of Lights switch
    By affirmation in forum Styling
    Last Post: 29th October 2009, 22:18
  5. LED lights conversion
    By daviek in forum Bodywork & Interior
    Last Post: 2nd October 2006, 20:51
error code with led lights vectra c
