Thread: Lowering Spring for 1.9CDTI
    Stratford upon Avon
    Default Lowering Spring for 1.9CDTI
    Can anyone point me in the right direction for lowering springs for a 54 Reg, Vectra C 1.9cdti. Have had no problems findning them for the petrol versions, are they the same?
    I want the car to sit about the same level at an SRI.
    Thanks,
    James
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Springs are the same for boths engine types. You need to know the weight of each axle. This is on the vin plate on the b pillar just inside the drivers door. Once you have these you need to google eibach springs which will lower your car 30mm which will be the same as an SRI. I personally would go any lower but several have. If you go lower you will need to replace the shocks but -30mm and the standard shocks are fine.
    Stratford upon Avon
    Just looked on the vin plate and the only two weights I can see says: 2025 and 3525
    But when looking at the springs it has axle weights listed as: 1135 and 1035
    Im confused
    Stratford upon Avon
    Ok turns out I wasnt reading the vin plate properly. My axle weights are 1070 and 980 kgs. When looking at the springs for my model it says weights up to 1035 and 1135 kgs. Do the axle weights on the springs you buy have to match up or is it a maximum figure?
  1. Anybody Used Lowering Spring Clamps???
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2013, 01:15
  2. Lowering Spring Advice.
    By tomtaylor15 in forum Handling & Braking
    Last Post: 27th January 2012, 19:04
  3. PI lowering spring advise
    By tom_p_2000 in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2009, 21:22
  4. Lowering spring problem
    By big O in forum Handling & Braking
    Last Post: 19th April 2009, 22:00
  5. PI Lowering spring
    By lee_eardley in forum Parts for sale
    Last Post: 24th May 2007, 21:10
