Thread: What's next?
    Oct 2009
    Oxford
    Engine : 2.2i
    Default What's next?
    I seem to be working through the standard problems with Signums. First was the fuel pump failure (common 2.2i petrol) issue. Spanner appeared, car goes into limp home mode and its off to the garage for a £600 bill. First day of our holiday too.
    Next was the tailgate catch. Tailgate stuck down, micro-switch clagged up. Took tailgate apart, cleaned up switch but it did it again so got new switch a couple of months later.
    Next it was clogged up drain by the heater intake, leading to footwell swimming pool. I bought a dehumidifier and dried it all out, cleared the drain.
    Finally it has been the common follow-on from that - failure of the resistor pack on the heater blower, so you only get fan speed 4. I've just taken it all apart and fitted a new thermal fuse from Maplin. It all works again.
    All these things seem to have been standard issues. I'm extremely grateful for this forum, it's saved me loads of time and money sorting this all out. But it leads me to wonder what's up here. Some of this was preventable and if I'd known the fault was likely I could have done something about it.
    So what's the next thing that's likely to cause me grief in my 2004 petrol 2.2i Signum Elegance? My money is on a failed suspension spring...
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    sounds the normal stuff unfortunately mate. could be suspension but hopefully you'll get a break
    Regular Member Jezzy's Avatar
    S.E
    The 2.2 issue also applies to the Vectra of course, so it's not something specific to the Signum. As for the blocked drain - the way to prevent that is through proper maintenance, which is the duty of the owner/driver to either do themselves or get someone to do it.
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Its funny how they clogged up so much considering how small the gaps on the scuttle panel is. On a separate note on this changing the pollen filter on a yearly basis will help prevent this reoccurring, as the rubbish will be seen and removed before any more damage can be done.
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    if you haven't had a broken spring or leaking damper so far then its a fair bet that you will need a new one sooner or later, you can either wait for them to go or you can make plans to change them beforehand i.e. know what you want and where to get them. its always best to replace such items in pairs and not just the corner thats failed.
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Someone could drive into you?
    Hit by a meteor?
    Jan 2010
    glasgow
    1 peeps hasnt said the dreaded chain lol change the oil as regular as u can mate the more regular oil changes the 2.2s get the better it is for them id say regular changes every 5-7k extreems 10k as its the oil that gets dirty and causes the oil jet for the tensioner of the chain to clog hence tensioner failure=chain failure
    Oct 2009
    Oxford
    Engine : 2.2i
    Sorry folks. It isn't a broken spring, leaking damper, meteor or someone running into me.
    I've got the fuel pump/fuel regulator problem again. Yesterday I drove across town, then on the way back stopped to do an errand. When I started up again the car cut out almost immediately. It did this several times till I gave up. I left it for twenty minutes, started it and managed to get home. Later yesterday I had to go pick up the wife. I got there OK, but it cut out approaching a roundabout shortly after starting back. So we sat in a side street for half an hour while the engine cooled, then we made it back OK. From http://www.vectra-c.com/forum/showthread.php?t=28293 it looks like this is the pressure regulator, hopefully the high pressure fuel pump is OK. If so this will be my second regulator :-(
