Thread: Auto Dim Mirror
    Full Member
    South West
    Default Auto Dim Mirror
    Just a quick question chaps...
    How do you know if your car is ready for an Auto dim mirror?
    Aidi
    Full Member
    South West
    Anyone? Mines a Vec C SRi 2006. Just want to make sure that it will work before buying one.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    to be honest no idea think their is a plug in the head lining for the mirror, auto wiper sensor and auto headlamp sensor as all linked. think the rec control unit would be different to.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Even if your car isn't ready for it, it's an easy retrofit. The auto dim mirror is a stand alone unit that will work in any car with a postivie and negative feed
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Even if your car isn't ready for it, it's an easy retrofit. The auto dim mirror is a stand alone unit that will wo in any car with a postivie and negative feed
    their you go mate always some one that knows what you want
    Full Member
    South West
    Cool, So the £40 loom from Vx is not needed?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    No but by fitting that roof loom i'm sure it gives you the wiring for the rear interior light too
    Full Member
    South West
    Thanks John, much appreciate info. Off to find a mirror now!
    Damn, this Vectra modding lark can quickly make you skint!
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Well when I fitted mine, the room loom had nothing to do with the rear interior lamps ....
    ... fitting the correct loom means no messing about bodging connections. Fit the kit (as per the How2) and it will more than likely work correctly (the auto dim sensors and the 'ambient light' down pointing amber lamp). If it desn't then you still have a perfectly good interior mirror until you find someone with either a tech II or Op-Com available.
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    i didn't have the loom in my 06 plate sri cdti150 but with a little extra wiring and a bit of solder its all in working fine . If you take out the interior light unit the loom will be tucked up there if its fitted but don`t be surprised if you have not got it. to add the vxl loom it needs to be run from the relay unit in the boot so its a roof lining out job so i cheated and took 2 feeds from the interior light unit and a 12v ignition live off the cig lighter
  1. auto dim mirror
    By Ray_Ray280 in forum Electrical & ICE (including SatNav)
    Last Post: 16th November 2011, 00:31
  2. For Sale: auto dim mirror
    By daddyjay in forum Parts for sale
    Last Post: 5th June 2011, 18:00
  3. Help needed - Auto dim mirror & poss auto wipers
    By mark_647 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 01:09
  4. Auto wipers.. and auto dimming mirror ?
    Last Post: 28th January 2009, 01:24
  5. Auto Dimming Mirror/Auto Wipers
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 21:42
