Thread: Signum CDTi150 - No heating?
    Regular Member mr-s's Avatar
    Sep 2009
    Shropshire
    Default Signum CDTi150 - No heating?
    I went to Alton Towers today, and en-route everything was working as per usual with the heater.
    On leaving, i turned the dial to 'hot' and the air temp didn't change from the 'cold' setting.
    Basically, the heater temp dial isn't making any ounce of difference to the air temp, all i get is cold.
    When i turn it from hot to cold, i can hear a 'click' noise from behind the dash (heat flap opening/closing?).
    Ive checked the engine over and the fluid levels ok and flowing, the temp is hovering between 0-80 as per usual so im baffled.
    Has anyone got any suggestions?
    Im seriously at my wits end with the car now. Ive only owned it a year, and it already needs nearly 2.5k worth of repairs!!
    - worst car ever owned by far.
    Thanks,
    S.
    preston
    given you have flow and engine temp ok then i guess we can rule out water pump failure / thermostat issues.
    other than that i's say initially i'd suspect the control unit is faulty being stuck in the cold position
    anyone else got any suggestions?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    the same as you mate
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    dont rule out waterpump m8 check coolant hoses to heater rad at normal temp to see if they hot check rad itself have had impella coming loose on waterpump causes same problem
    Quote Originally Posted by paul wingnut View Post
    the car would overheat with a dodgy waterpump wouldn't it?
    My money is on a dodgy servo.
    Sep 2009
    Shropshire
    Thanks for the rapid replies so far guys.
    Ive checked the coolant hoses, and they felt hot, also the water was visibly moving in the coolant bottle whilst revving the engine.
    How could i find out if its the servo causing problems?
    If so, is it an expensive fix (as everything on this car seems to be )
    Cheers,
    S.
    May 2008
    newcastle
    my heater flap got stuck in the cold position last week, you could hear a click when i turned the heating control to hot, i removed the glove box to expose the control arm & motor, gave it a wobble & hey presto it started operating again, gave the linkage a quick squirt of oil & it's been fine since.
    might be worth a go mr-s
    Sep 2009
    Shropshire
    Quote Originally Posted by john1 View Post
    Thanks for that.
    I don't suppose you have any pics of the control arm and motor's location, so i know what im looking for?
    Also, how easy is the glovebox to remove?
    Cheers,
    S.
    preston
    happened to mine its the little electric motor that operates the flap. glove box out and give it a wiggle and it will be ok. spray a little wd 40 and operate the heater loads of times to 'free' it
    PRESTON
  1. Signum CDTi150 serious electrical problems.......... help!!
    By mr-s in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2011, 14:06
  2. Heating temperature control not working - Full heating permanently
    By jratcliffe3 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2010, 23:46
  3. Signum Heating System Problem
    By Lotus_c_man in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2009, 14:04
  4. Brakes Signum CDTI150
    By raddish in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2009, 06:40
  5. CDti150 Tuning box
    By mikey68 in forum Parts for sale
    Last Post: 29th May 2009, 21:12
vrctra c no heating
