Results 1 to 10 of 16
Thread: brake help please
    Regular Member sristeven1's Avatar
    wirral
    Default brake help please
    right trying to replace my discs and i have managed to get pads and every thing elso off but having problems removing two caliper carrier mounting bolts they wont move at all any advice please
    Regular Member Dazzy2006's Avatar
    Notts
    Try putting a long tube or spanner on the end of the allen key - should give you a bit more leverage
    wirral
    no it not them ones mate got them out fine its the other ones that hold the caliper carrier on that needs a e20 star socket
    Notts
    Quote Originally Posted by sristeven1 View Post
    Ah ok - Try putting a long tube or spanner on the end of the Rachet - should give you a bit more leverage
    Regular Member Jezzy's Avatar
    S.E
    They need a huge amount of torque to undo them - you need to put something like a 4 foot long pole over the handle of your ratchet, and make sure you E20 socket is the half inch size, not the smaller one with an adaptor, as the adaptor will snap with the force you put through it. Make sure you've turned the steering wheel so that the caliper is pointing outwards, not tucked under the steering wheel, otherwise you won't be able to fit the extension bar to the ratchet.
    Sodding Typical on Sea
    I cheated personally I used a 15" breaker bar and the cars own scissor jack to provide the muscle! worked a treat too
    wirral
    thanks will give it a try tommorow fingers crossed it works
    wirral
    thanks for the advice guys managed to remove them bolts on the front now just need to do the rears tommorow fingers crossed i dont have same problems all this effort to put drilled and groved discs on lol
    Notts
    Dont forget you need a brake rewind tool or pair of longnose pliers to do the back
    S.E
    The rears don't need quite so much force, you'll need an E18 rather than an E20 though.
  2. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  3. yellow brake calliper brake set
    By The Gas Man in forum Parts for sale
    Last Post: 22nd July 2010, 22:41
  4. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  5. Brake kit for GSi
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2007, 23:06
