Results 1 to 3 of 3
Thread: Vectra 04 plate Both Front Cigarette lighters not working!!
    Sep 2010
    essex
    Default Vectra 04 plate Both Front Cigarette lighters not working!!
    I was trying to use the original lighter to heat it up..Usually I puch it little longer after getting hot a bit to make it red hot. Anyways it suddenly stopped working. I checked the fuse on the passenger side on the side of the dashboard and 30AMP fuse was blowen. I changed it with a new one but bot front lighters are not working!!! One at the boot still works fine.... Any suggestions or help?
    Its a vectra cdti 150 estate Elite...2004... And yes the ignition switch is on...
    Just a quick note the lighter head got really hot before going completely dead!!! Also I have changed the front lighter the one by the CD player... Both of them including one behind the arm rest isnt working....
    Thank you for your answers guys...
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    maybe the wirein shorted out to much heat
    Sep 2010
    essex
    Ok, I thought of that too actually...Thank you for reminding me again, how do I follow the wires? I guess from where the main lighter by the cd player then under the glove box then where the side (passenger side) fuse box?
    Anything else it might be???
  1. vectra 2.0 turbo sri 07 plate front coil spring help
    By matrix1979 in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2012, 20:31
  2. Wanted - Std front Struts 52 plate vectra C diesel
    By MARKPRIOR in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2011, 16:31
  3. Front cigarette power point
    By skip85 in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2011, 19:30
  4. cigarette lighter front Vectra C
    By CristianTM in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2008, 18:04
