Results 1 to 10 of 25
Thread: Under Bonnet Lights & Footwell Lights...
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Default Under Bonnet Lights & Footwell Lights...
    Will do a proper How2 no doubt but a couple of pics of my progress today. Did the footwell lights then got bored so started the under bonnet ones...
    Not finished yet as my mate was supposed to blow in under the bonnet but when i got up to his garage he was too busy ... Its going to be for free of course tho so i'll let him off...
    Fitted the switch to the battery box to kill the light, Just in case i'm working for a bit under the bonnet... Alarm Pin switch fitted to the wing for the earth point so they will come on as soon as the bonnets opened
    Wont be sprayed now till next Sat But it gives time for the other LED boards to turn up and my Frosted PVC sheets
    Also, see this link if you need another option for the Footwell lights power rather then connecting to the bulb holders
    http://www.vectra-c.com/forum/showpo...8&postcount=25
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Ah. I thought you were just going to wire it up to switched negative for the alarm. Is that a switch on the underside of the bonnet too?
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    I was going to just use the alarm pin switch, but if i've got my head under the bonnet for an hour i dont want them permanently on, so switch is to turn them fully off...
    And that the same switch on the bonnet, was my 1st plan, but you cant feed the power wire up to that as the bonnet skins touch. but the switch on the battery box is hidden so maybe a little better...
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    More Work and pics... Coming along nicely.
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Lens covers for the LED's, 6 to be made in 5mm frosted PVC but 2 are for spares...
    Cant wait for this all to be done
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    looking good lee
    Engine : 1.9 CDTi
    Would there be enough room to put a 5w side light bulb under there?
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Quote Originally Posted by lee gsi View Post
    Possibly... But there's only about a 1cm gap tho between the top skin and the holes in the bracing...
    I've got 3 of these, and one more hopefully turning up tomo...
    Sticking them directly to the upper skin, then the frosted lenses are to be screwed in over the 4 cut outs... Hopefully it'll look kinda factory rather then some led strips rammed everywhere....
    Engine : 1.9 CDTi
    My plan was to piggyback the side lights as the under bonnet lights so the leds dont flicker
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Piggy backing still causes flashing tho when the lights arent on. Even if the standard side light bulbs are in place.......
  1. Footwell lights
    By conman in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2012, 20:04
  2. footwell lights
    By brod999 in forum The 'Off Topic' room
    Last Post: 4th December 2012, 23:38
  3. LED footwell lights??
    By harley270906 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2010, 12:21
  4. Footwell lights
    By VECTRA HEAD in forum Electrical & ICE (including SatNav)
    Last Post: 26th October 2009, 21:46
  5. Footwell Lights
    By RMJonny in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2009, 15:12
