Results 1 to 10 of 14
Thread: 1.9cdti misfire
    Jan 2010
    WEST YORKSHIRE
    Default 1.9cdti misfire
    Any help or advice on this problem,would be gratefully accepted as i am at a loss to what actually is the problem.
    I have a 2006 1.9cdti vectra 8v,which i can only discribe,has an engine misfire between 900 and 1500 rpm.
    On starting it runs like,"a bag of spanners" till its warmed up,but has this annoying misfire which actually vibrates the whole car if held at 1200 rpm.Above this,and general running it seems to disapear,doesnt seem heavy on fuel,but yesterday i was driving up a slip road to join the m62,put my foot down,and bang,seemed to backfire,and a cloud of smoke was left behind the car,but doesnt seem to be smoking heavily,other than that.Have done 3rd injector rewire,cleaed egr,and boost sensor,cleaned all other injector plug connectors,but still got the misfire.
    The only other thing i can tell you,upon start from cold,spanner light comes on,and stays on for about 45 seconds,then goes out,n wont come back on again,till the next start from cold.
    Any advice would be great,as it is really doing my swede in now,lol,thanks in advance
    Jan 2010
    WEST YORKSHIRE
    Default 1.9 cdti misfire
    By the way,car has done 160,000 miles doesnt use excessive oil,or water either.
    PRESTON
    cold starting issue might be glowplugs on the way out. Have you cleaned the egr valve and boost sensor? Also check the small vac hoses that control the turbo boost valve for perishing or splits. The large boost hose on the right sideof the engine should be checked for small splits too, usually underneath.
    preston
    has it been serviced recently? fuel/ oil air filter etc??
    i'd guess this might be a egr thats sticking open then suddenly shutting / partially shutting
    i'd temporarily blank my egr first then see if problem goes away.
    if it does egr to blame
    if not elsewhere is your solution
    Jan 2010
    WEST YORKSHIRE
    its not that it wont start,first turn every time,its just lumpy on tickover.
    egr cleaned today,n fiat restricted flow egr gasket,n found a split vacuum hose,its better,but still not quite there
    Jan 2010
    WEST YORKSHIRE
    more grunt altogether after fitting fiat egr gasket,no spanner light or eml light,would advise anyone to fit one
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Quote Originally Posted by chaosmunkey27 View Post
    i 2nd that, if fitted the fiat gasket the other day and power seems to be quite a bit more and smoother too
    Regular Member Marky's Avatar
    Jun 2006
    North West
    I think that fixing the split hose has given you back your power.
    And the blanking of the EGR means that the power delivery is alot smoother.
    Still got to sort out fitting my gasket on the EGR.
    Whats left to sort out on yours now??
    Jan 2010
    WEST YORKSHIRE
    the misfire,its so lumpy on idle,up tp 1600 rpm
    Jan 2010
    WEST YORKSHIRE
    Default misfire
    turned out to be an injector faulty,new 1 fitted,right as rain now.
  1. Part load misfire 1.9CDTi 150
    By Python in forum Engine & Drivetrain
    Last Post: 12th November 2012, 17:40
  2. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  3. Lets get this misfire sorted!! (1.9cdti)
    By Jackvectra18 in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2011, 20:10
  4. 1.8 misfire
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2010, 23:09
  5. 2.0 dti misfire
    By Micknal in forum Engine & Drivetrain
    Last Post: 30th September 2009, 17:15
