Thread: 1.9CDTi Wont Start After Coolant Light On
    Regular Member s-owen4's Avatar
    Aug 2010
    Consett
    confused 1.9CDTi Wont Start After Coolant Light On
    Hi Folks
    My 1.9CDTi (150) wont start now after the coolant warning light came on and the car ground to a halt. The expansion bottle was empty although I can not see any apparent leaks. I have refilled the system, but now the yellow spanner is showing and the car wont start, any ideas??????
    Full Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    WilliamLX had same problem on his 1.9CDTi
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Safety device ?, code might need clearing.
    EVERYWHERE
    Many ECUs put engines into limp mode and stop them from being started again if the coolant level is too low.
    Water pump seems to be one area on these engines that can give trouble.
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by diesel dog View Post
    Wouldn't surprise me, you be amazed what stops an engine being run.
    I was told how engine management systems used to shut an engine down just due 'slight drop in oil pressure' ie it was within a reasonable tolerance but the ECU decided not to play ball.
    One of the worst things is Engine management systems on modern ICE's.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
  1. 1.9cdti 150 wont start after just after cutting out during run
    By tony660x in forum Engine & Drivetrain
    Last Post: 20th October 2012, 20:28
  2. Replies: 3
    Last Post: 5th January 2012, 19:15
  3. 1.9cdti coolant light and temperature guage help please.
    By martin19842 in forum Engine & Drivetrain
    Last Post: 10th March 2011, 10:39
  4. 1.9cdti wont start following waterpump/belt fail
    By richsimpson in forum Engine & Drivetrain
    Last Post: 9th March 2011, 19:57
  5. wont start 1.9cdti
    By otl1uk in forum Engine & Drivetrain
    Last Post: 19th November 2008, 20:11
opel car wont start coolant warning on
where do I put antifreeze in my vectra cdti
vaxhall wont start low radiotor light
