Thread: Clutch vibration
    Sep 2010
    Derby
    Default Clutch vibration
    I've just bought an 06 Vectra 1.9 CDTi SRi which has just (2 weeks ago) had the DMF and Clutch changed.
    When I put my foot on the clutch whilst driving (just resting on) I feel a faint vibration. This is also there when getting the biting point either with a gear selected or not. The vibration seems to be in time with the engine.
    It's only very faint and no noise but I wonder if it is something to worry about?
    Any advice would be very welcome.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Bud if you feel insure about it take it back to where the clutch was fitted and mention it. My car is the same as yours and I've not got any vibrations thru the pedal
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    i had clutch vibration so changed flywheel and clutch vauxhall done the work. sri 120 i still have the vibration 4 months on, no one has give me any answers as to the vibration, i just got used to it by now and drive it on.
    preston
    I changed my own dmf and noticed slight roughness when pressing clutch pedal, I put it down to slight out of balance maybe with the new clutch, nowt to worry about, its been like it for a year
    PRESTON
    A slight vibration via the pedal is quite normal and nothing to worry about. It's the movement of the concentric slave cylinder being transmitted through the hydraulic fluid.
    preston
    concur with above
    if you've a problem with clutch / DMF /bearing it'll either
    a) tell you with lots of warning ( sounds like bag of spanners being rattled at front of car )
    b) like mine - fine one minute - dropped pedal next ( with hindsight - missed / difficult couple of gear changes in week before - maybe that was its clue )
    wish someone would come up with a better soln to DMF but then i guess it does its job in reducing vibration
    Sep 2010
    Derby
    Ok, thanks. I'm reassured by these posts. Like I say, it's only very faint. Just not used to it I guess. Other than worrying about what might go wrong, it's a fantastic car.
    Regular Member FatboySteve's Avatar
    Bedfordshire
    My clutch pedal vibrates a bit as well, nice to know it's nothing to worry about
    Wales
    Same here with clutch vibration - I have (or rather had) the same. You get used to it very quickly and I dont even notice it now...
  1. Clutch pedal vibration
    By Ianz in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2011, 13:41
  2. New clutch and DMF but still vibration in pedal
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 29th September 2011, 16:54
  3. still vibration from clutch
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2010, 20:05
  4. clutch vibration
    By morphhprom in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2009, 21:20
