Thread: Engine Cuts Out
    Regular Member bulletproofpanda's Avatar
    Sep 2010
    Nottingham
    Default Engine Cuts Out
    Evening
    Have a 2004 2.0 dti that has a semi recurring problem. Usually in the morning when engine is cold, turn electrics on, wait for glow plug light to go out and turn over, car fires and runs for 5/10 seconds and then cuts out.
    Turn the car over again and starts after about 30-60 seconds of turning over and lots of smoke out of the back. Whilst turning over lots of smoke out of the back (much to the neighbours dissatisfaction!) and will "take" and then a bit more and a bit more until fires up and more smoke as you rev it for the next 60 seconds.
    Drives normally, no EML, no spanner, no limp mode just wont fire.... Quite frustrating and as have to leave at 0400 for work don’t want to alienate the neighbours....
    Any ideas / suggestions appreciated....
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    do a 'search' for leak off pipes or fuel drainback
    Diesel is running back to the tank due to an airleak somewhere, most probably the leak off lines
    Sep 2010
    Nottingham
    cheers... appreciated...
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Bud
    leak off hose is sold at your local discount spares shop,1 Mt is plenty about £4. pretty easy job to do,no special tools needed.
    stockport
    Quote Originally Posted by jonnybravo View Post
    Hi Bud
    I am buying some 4mm silicone tubing to renew the vacuum pipes,would this be ok to use as leak off pipes on the 1.9 CDTI do you think?.FELIXX.
  1. 2.0 Dti engine cuts out Signum
    By martutd in forum Engine & Drivetrain
    Last Post: 19th March 2012, 08:35
  2. Engine Cuts Out at low speed
    By rocket999 in forum Engine & Drivetrain
    Last Post: 30th January 2011, 12:04
  3. Engine cuts out
    By Lloydy in forum Engine & Drivetrain
    Last Post: 26th May 2010, 12:52
  4. engine cuts out
    By thedhj in forum Engine & Drivetrain
    Last Post: 7th February 2010, 14:07
  5. Engine cuts out
    By Chippie19 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd August 2009, 09:22
