Results 1 to 10 of 16
Thread: Tracking!???
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default Tracking!???
    Wat are the symptoms of tracking been out? I know tyres can wear on inner edges but is there any other symptoms? Cheers guys
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    car pulling to one side!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    They car wear out on inner and outer edges. The car can be very twitchy in a straight line or pull to one side.
    Sep 2010
    Leeds
    Nah none of that, jus been reading few threads on tracking after had lowering springs fitted, and i only paid £80 for the fitting of my 35mm apex springs, so was worried coz it was cheap price they might not have done tracking! But i dont having any pulling to one side issues so they must have done everything right, fitted over 6 month now and not noticed owt anyway. Although my 2 front tyres was slightly bald on the inside before i changed em, cud this be it or wud the pulling have to go with it as a symptom or is pulling not always a symptom? If ya know wot i mean
    Regular Member Jezzy's Avatar
    S.E
    Car dances all over the road when going over rough/bumpy roads.
    Vehicle : SRi
    Mileage : 137000
    Its the camber that will need looking at if anything.
    Sep 2010
    Leeds
    Camber????
    May 2008
    Tyneside
    Oct 2009
    Herts
    Tracking if wrong scrubs the tyre laterally making the tread feel sharp, in most cases you don't notice it's wrong unless it's violently wrong, in addition it cannot make the car pull.
    Camber is the vertical lean of the wheel, if wrong the wear is confined to one edge and smooth, incorrect camber can make the car pull.
    Quote Originally Posted by Jow20 View Post
    Which type of wear are you seeing? You don't mention whether it is front, rear, nearside or offside
    Front tyres typically wear on the outside edges, usually more on the nearside than offside
    This is a sign the vehicles spends more time at low speed corners, typically roundabouts
    Rear tyres (on the Vectra C) typically wear evenly on the inside edges (both sides)
    This is due to the camber settings at manufacture
    The tyre manufacturers now simply report that as a charateristic of the vehicle
    Once the camber has been reset the issue disappears
  1. tracking?
    By chris1804 in forum Suspension, Wheels & Brakes
    Last Post: 29th November 2012, 10:32
  2. Do i need tracking doing
    By big nath in forum Suspension, Wheels & Brakes
    Last Post: 27th June 2009, 05:15
  3. tracking
    By bigron1988 in forum Suspension, Wheels & Brakes
    Last Post: 31st October 2008, 17:20
  4. Just got the tracking done....
    By Stevie-B in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2008, 20:52
  5. Tracking
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 1st October 2007, 16:55
