Thread: smell of petrol
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Default smell of petrol
    aryt guys
    (52) vectra c 1.8 LS Petrol
    what kinda mileage should i be getting just driving locally ?
    have notice that i am going through the petrol good style,think i am getting bout 120 miles for £20,is this bout right or wot ?
    never really noticed it before,i put £50 in tank couple of days ago,now the smell of petrol is STRONG,have checked and sure i aint got a leak,even when driving i can still smell petrol,but not as strong as when i pull up get out the car
    any ideas peeps ?
    cheers
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Any sign of it leaking anywhere? Maybe check the fuel filter, just under OSR passanger door in case thats corroded.
    I remember with the Mk2 and 3 cavis the rubber fuel lines used to perish where they changed from metal to rubber from the base of the engine bulkhead to fuel pressure regulator. Im not sure if the Vec is the same but worth a look too.
    Aug 2010
    Dundee-Motherwell
    worth a try m8,will check it out tomorrow
    what do you think of my mileage ?
    cheers
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Thats about 31mpg, but that depends on what kind of driving your doing. I get 39mpg combined, but them most of my driving is commuting to Edinburgh and back on the M8. If your mostly town driving its not that bad.
    Id rule out the petrol tank as they are plastic now, so no worry about them rotting. Weak point is defiantly the filter mate, the wifes rotted away on her punto and youd be surprised that all it takes is it to be weeping a bit to give a strong smell. Do you know when it was changed last?
    Aug 2010
    Dundee-Motherwell
    aint got a clue when it was last changed m8,i checked on fleabay just now and if its same filter i need its only bout £6 posted
    so unless someone else here tells me summit different i will check the filter in the morning,just hope its where you said lol
    cheers again m8
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Sounds about right for a fuel filter. They have special release clips, but I think you can get away with a small screwdriver just take it easy cause they can break.
    Aug 2010
    Dundee-Motherwell
    i will do m8,let u know in morning once i have checked it
  1. I Smell Petrol
    By Tam80 in forum Engine & Drivetrain
    Last Post: 4th June 2011, 12:54
  2. Petrol Smell
    By CDTi-SRi-Matt in forum Engine & Drivetrain
    Last Post: 5th February 2009, 21:20
  3. Petrol smell
    By cjm4378 in forum Engine & Drivetrain
    Last Post: 24th February 2008, 23:33
  4. petrol smell
    Last Post: 22nd November 2007, 19:40
  5. smell of petrol
    By kevinmcm19 in forum Vectra C / Signum Troubleshooting
    Last Post: 21st November 2007, 23:16
