Hmmmmmmm I might have to look into the door handle lights!
These would look good. maybe just one each hidden away...
5mm LED
http://cgi.ebay.co.uk/20x-White-LED-...item53e3a1f4b2
5MM bezels
http://cgi.ebay.co.uk/black-5mm-led-...e#ht_768wt_911
i,ve bought these mate,
http://www.led1.de/shop/product_info...s-2pins-p-1174
http://www.phenoptix.com/shop/white-...ape-p-128.html
hopefully i can get the connectors to work lol
yeah I was planning to put it into the holders but I'm sure you will show me a better way lol
Right, all sorted and wired up...
The wire you need to take the power from is the WHITE/BROWN.
Comes on with key fob, doors open etc...
The other BROWN is the earth, It appears the BLUE/RED is for the on/off switch on the light, and i gather the GREY has something to do with the alarm as its only live after the doors are deadlocked and very low power...
Was going to solder direct onto the circuit board to the cetre 2 (see pic below) but i tapped into the wires instead as the original solders are too close together on the board for my soldering confidence level
Maybe someone could add this pic and the above description to the how2...?!?
think i'll try this 2moro cheers mate
Nice one Lee, I'm deffo going to do this. In fact I've got loads to do. The front skirt is off getting a respray and i have a new VXR insert waiting to get sprayed as the old one flaked. To make things worse my only man drove down the side of my rear bumper at the weekend and took the paint off so I've got plenty to be getting on with.
First idea is a LED pointing down and my second is a LED or SMD behind the actual metal handle where it butts up against the door cards, this would hopefully give a halo glow around the handle.
I need my splitter spraying again, caught it twice in as many days... Only underneath on the top of speed bumps but still a mess...
By way, have you changed the air pipe on yours? Been looking at silicone hoses and alloy pipes but not sure on size... Is it 70mm/ish for the 2.2?
Off the top of my head its 70mm I think, just check the external diameter of the MAF. Apiro do a nice alloy pipe with input for cam breather. If you get a 90 for the TB you might have to cut down one of the legs also as it might hit the bonnet top. I have most of the bits in the cellar including a Cotton Green Twister (like the Apollo or Viper) but never got round to fitting them.
Have you got a link to those led strips, as Crazy Leds are out of stock.
Yeah, i was thinking either.......
90' silicone bend - straight pipe - 45' bend - AFM
Or
90' bend - 45' pipe - straight silicone - AFM.....
I'll just fit a catch can or breather for the cams.
