Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Interior Light Circuit Board - Anyone Help...
    Hanging Heaton / Batley
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Default Interior Light Circuit Board - Anyone Help...
    Anyone know which wire to take the power from if fitting footwell lights, I will just solder to the bulb holder if not...
    Earth is brown obviously, then there's a solid grey. Then 2 stripped, blue/red and white/brown...
    My interior is the NON map light one so only 2 buttons. so i'm thinking the striped are for the switches making the solid grey the feed... Anyone want to please correct me before i break anything
    23 Post(s)
    Mileage : 110k
    Sorry, also while footwell lights has anyone got a pic of how you attached to the underside of the seats for the rears...
    There's white plastic brackets under there to hold the various wires, but these sit a bit far in for my liking... I coud just attatch to the edge of the liner fabric (not the outer rear cover) but i cant see it staying put....
    There the sticky backed flexible SMD ones i bought so to cable tie them to springs etc might be a problem.... (see pic below)
    Its been one of them jobs i wish i hadn't have started. Been put off for months as one interior light screw would not come out, took about an hour just on that!!
    Regular Member Steven T Davies-Moss's Avatar
    shropshire
    Quote Originally Posted by leemarksmith View Post
    Looking at the picture.. the cable linked to the lights is the white/brown ( if i remember right )... just follow the pathway set out on the board
    A picture of the whole board would be better.. as two of the lines to the back.. could be either of them
    Liverpool
    when i fitted mine, i wired them to the coursety light holders
    23 Post(s)
    Mileage : 110k
    I'll try take a bigger pic tomo... If it comes i'll cut the lot, only 3 attempts to get right...
    shropshire
    Its not the blue / red
    Im sure it's the middle two
    u not got an electrical tester ?
    23 Post(s)
    Mileage : 110k
    Yeah, but you cant get access behind when the ribbons connected as there's no room for it to hang... The middle brown is the earth so i'll try the white/brown 1st...
    Just thought someone might know straight off, Where the hells Robsey
    shropshire
    I hung mine while i tested it ... ... job done
    23 Post(s)
    Mileage : 110k
    I'll try release more ribbon... Just dont trust them, already need a new one as i nicked it fitting the rear light months back...........
    actually. i'm guessing the rear light will narrow it down as it only has the 3 wires to the board... There was a how2 for the rear light without the rear ribbon but there's no pics now
    shropshire
    Yeh.. i soldered the rear light to the front lights .... so it dims the same but the extra cable is prob for the rear light permanant live
    I then upgraded the roof loom to include sun visor lights and rain sensor
  1. Circuit board removal 2 button flip key fob Vectra C
    By pedro26 in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2012, 16:28
  2. Any PCD/circuit board Guru's among us ?
    By markm in forum General Chat
    Last Post: 7th October 2012, 08:20
  3. Heated seat switch circuit board
    By tappetpaul in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2012, 12:20
  4. Is the cd70 pcb circuit board coded as in a need a new board
    By gurjsagoo in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2012, 00:07
  5. photo Request... Circuit Board inside your 3 button flip key
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2009, 20:58
vectra c interior light wiring
what wires go to interior light on vectra c
tear light pcb for vauxhall vectra c
2008 vectra interior light wiring
vectra c interior light pin
vectra c interior light circuit diagram
vectra c rear interior light wire loom
vectra c courtesy light wiring
vectra courtesy LIGHT PCB
