Results 1 to 10 of 28
Thread: EML on and major loss of power
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Engine : 1.9 cdti 150
    Mileage : 119k
    Default EML on and major loss of power
    Hi All,
    Have just joined to see if anyone can help me out with the following problem.
    Ive got a 2003 Vectra 2.2 Dti. For the last few months I've been having a problem with the engine management light coming on and the car going into a 'limp home' mode and losing all power. Very scary situation.
    For the last couple of weeks its been getting more frequent. Turning the ignition off then on clears the light but sometimes it comes on again after a few minutes, other times it doesn't happen for a few days. I've tried cleaning the MAF with isopropyl alcohol but not made any difference.
    Can anybody give me any clues as to what it might be?
    I will try the brake accelerator pedal trick to show fault codes when my wife gets home tonight with the car.
    This problem also occurred about a year ago, we took it in to Vauxhall dealer who read the codes and cleaned the boost sensor. The problem seemed sorted until about 3 months ago.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    check boost pipes for splits mate most common is under the plastic cover on top of the engine
    Regular Member Dazzy2006's Avatar
    Notts
    As above and also clean the egr valve and boost sensor - there really common problems on the dti
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    it most certinaly is
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Mileage : 119k
    Thanks for the speedy replies.
    I have checked all hoses and pipes and all appear to be ok. (Although the car has always had a hissing sound when coming off the accelerator)
    Is the boost sensor to the right under the engine cover?
    Can someone tell me where the EGR valve is please? I know its a mucky job cos I have cleaned the one on my mg zt cdti.
    Notts
    Egr valve how to - http://www.vectra-c.com/forum/showthread.php?t=60856
    Yes the boost sensor is on the right and held on with 1 bolt
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Mileage : 119k
    Thanks Dazzy2006. Any recommendations for what to use to clean the boost sensor?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    carb cleaner or alchol be carefull though its very delicate
    preston
    carb cleaner and soft toothbrush
    Notts
    What they both said apart from theres no way on earth im using alcohol on mine - i'd rather drink it thanks paul
  1. Major loss of power
    By WeDesign in forum Engine & Drivetrain
    Last Post: 17th September 2012, 13:51
  2. major power loss and engine noise
    By martin.lake in forum Engine & Drivetrain
    Last Post: 17th September 2012, 00:13
  3. 1.9CDTi Major Power Loss
    By GlennM in forum Engine & Drivetrain
    Last Post: 22nd May 2010, 21:59
  4. Major loss of power
    By martinmack in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2009, 18:58
  5. No power after major problems
    By adam3682 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th August 2009, 15:16
vectra c 1.9 eml no power
