Thread: Where's the Boost sensor on a 3.0ltr V6 Z30DT?
    Regular Member ph67's Avatar
    Northamptonshire
    Default Where's the Boost sensor on a 3.0ltr V6 Z30DT?
    Could someone please help me out and point me to where the boost sensor is on the 3.0ltr V6 CDTi Z30DT engine? If you've got a picture that would be really helpful?Thanks
    It's already on here somewhere. Celes posted one up iirc.
    Northamptonshire
    Great - Thanks, I'll use the pic and your description and have a look for it.
    Northamptonshire
    ....also, what should I use to clean it with? I assume I it's going to be a case of carefully wiping any muck out of it and not letting any liquid get into it? (Not sure if it's electrical or mechanical parts inside) Thanks
    Wire brush and carb cleaner
    Northamptonshire
    OK, two questions then, firstly how do I get the Boost Sensor off? I've seen various links for DTi and 1.9 engines, what about on the 3.0ltr V6 Z30DT?
    Secondly, what's the best way to clean it?, should I ensure the carb cleaner is only used on the outside or can I pour it inside to flush the muck out without causing a problem? - not sure what's inside the thing
    Northamptonshire
    Ah, took the cover off the engine at the weekend again and had a look in the area described in Big Sig's link - no cable tray and nothing with 'Boost' written on it in that area - instead there isa metal frame with two black boxes attached to it - they look like control units - both about 6in x 6in x 1in and both with two substantial cables connected - I looked to the right of that framework and under it but nothing there as described.
    Lookslike Big Sig's thread was for a Y30DT engine (as it was an 03 siggy) and maybe there's some differences to the Z30DT (which I have) in that area.
    Any help appreciated please?
  1. 120 boost sensor , where is it ??
    By bembo449 in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2011, 13:38
  2. Boost Sensor & 10K Boost
    By hebdendave in forum Diesel Engine related
    Last Post: 13th February 2011, 17:43
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
vectra c v6 boost sensor
vectra v6 boost sensor
z30dt boost sensor
