Results 1 to 10 of 15
Thread: disconnect battery after remap?
    Jun 2006
    teeside
    Default disconnect battery after remap?
    what do think? had it done a few weeks ago now, but jayson never once mentioned doing this
    how do you stand with central locking and radio codes etc if i do this.
    jayson advised us that we should re set the ecu every 3 months or so .... but i dont know about doors and stereo though chap ! as he reset mine via the laptop !
    Just here!!!
    Wink
    you should have a in your manual or some where the locking code for your stereo if not go to a vauxhall dealler and they will find out for you!
    the doors will reset them selves after a while but you can manually lock them with the key! hope this helps!!Your battery only has to be off your car for 20 mins m8 and no one can nick your car cus it's not attached to your battery any valuables advise remove from your car perhaps.
    [Ex]Admin Duncan's Avatar
    Won't affect central locking. All you should need to do is re-enter your radio code and you may need to reset any windows that don't keep going up/down once you've let go of the button on the door. All you need to do is wind down the window (using the drivers controls), then wind it up but keep the door button pressed once it's closed. Keep it pressed for a few seconds - I think you hear a little click - then the window will be back to normal.
    It'll also reset your trip/fuel computer.
    HTH
    Admin plasma's Avatar
    On the Forum
    217 Post(s)
    Engine : 150
    Mileage : 74000
    I tried disconnecting my battery the other night and my car alarm went off. think its got a battery backup on board?
    Just here!!!
    Wink
    thats strange mine did'nt m8 did you take the battery off when the alarm was set ie:the doors were all locked that could have been the problem!Otherwise i don't know to be honest!
    Jun 2006
    teeside
    nice one fellas will go and see if i can find the radio code as dont want to take it off now and have no music till monday
    dont know if it will make any difference to performance, but as the wife keeps telling me, every little bit helps
    SOMERSET
    I done the same 4 days ago, i never lost any radio codes or anything else. Jayson never mentioned to me either about any mods, then reset the ecu. You would think it would say when you buy a air filter or any other performance mod to do this, oh well.
    The car changed straight away in the sound of the engine but after 150 miles really has settled down and i THINK it is better. Iam going back to chipped uk next week hopefully and i will let you know if the reset has made a difference.
    Quote Originally Posted by plasma
    Yep, the siren has a battery in it - so that people can't just disconnect the battery to disable it. You've got to disconnect the battery within 30 seconds of turning off the ignition so that it doesn't do that.
    Jun 2006
    teeside
    dont think i can get from the drivers seat and do 10 turns with a spanner in that time
    slightly off topic i know,but should a 55 plate 1.9cdti have traction control?, because mine certainly hasn,t
  1. battery off to reset remap?
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2013, 00:03
  2. CD30 battery disconnect
    By 19CDTi in forum Electrical & ICE (including SatNav)
    Last Post: 14th April 2012, 20:48
  3. Disconnect battery?
    By yoclick in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2009, 09:46
  4. Will I need to disconnect my battery
    By ballmonkey in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2007, 14:37
  5. Problem after battery disconnect
    By Penfold in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2007, 20:02
