Thread: 05 Vectra CDTi - Blown bulb warning light?
    Sep 2010
    West Lothian
    Default 05 Vectra CDTi - Blown bulb warning light?
    In the past few days, my 'blown bulb' warning light has decided to come on, however, after checking all the bulbs in the car, all are working ok?
    Any idea's?
    stockport
    Quote Originally Posted by gmc View Post
    Any idea's?
    Your electrical system works on a type of voltage level recognition.As the filaments in your bulbs decay,the system requires more voltage to keep the bulbs lit.This is called resistance and the system will show a bulb failure prior to the bulb actually blowing because of the raised voltage.
    This is especially common with the indicator bulbs as the amber lacquer on the bulb "flakes" off causing the system to generate more resistance as more current is needed to keep the bulbs brightness constant.
    Aren't canbus electrical systems just great!!!!.FELIXX.
    Sep 2010
    West Lothian
    Thanks Felixx!
    Well, I ain't planning to change every bulb, so I guess I'll just wait on the culprit giving up the ghost!!!
    Thanks again
    It's normally the 21W bulbs; brakes, tail lights, indicators, reverse
    Sourcing it is usually easy enough
    If your car has the Driver Info Centre, it will advise you which one of those has failed
    Then simply replace those, wait about 90 seconds to see if the warning clears
    However, I do agree, it is over sensitive
    I sent a passenger to the rear as they noticed the warning had come up, then came back, "I can't see any that aren't working"
    Later that night I swapped both brake lights
    8 Post(s)
    Double check your brake lights. If the upper tail/brake light fails, then the lower tail light takes over the role of tail/brake light instead.
    Sep 2010
    West Lothian
    good tip thanks!
  1. bulb warning light on....but no bulbs appear blown
    By rjw in forum Vectra C / Signum Troubleshooting
    Last Post: 12th October 2010, 01:18
  2. Blown Bulb Warning...
    By VikBee in forum Vectra C / Signum Troubleshooting
    Last Post: 7th August 2009, 17:46
  3. Blown bulb warning light
    By Ant S in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2009, 23:09
  4. Blown Bulb Warning Help??
    By Jolly in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2008, 00:15
  5. Blown bulb warning light on dash??
    By Genterz in forum Vectra C / Signum Troubleshooting
    Last Post: 9th August 2008, 11:10
amber bulb warning lights opel vectra
