Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Retro fitting cd70 nav
    Regular Member family guy's Avatar
    Jul 2009
    salisbury
    Default Retro fitting cd70 nav
    Hi guys, i have a 2007 sri and was wondering has anyone retrofitted the nav in there car? I have the stereo in already and it works fine but im trying 2 work out the nav function. Ive got the looms, has anyone got any idears/advice?
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    can be done, need the screen, cd70, aerial, looms etc. what stereo do you have in there now?
    Regular Member Steven T Davies-Moss's Avatar
    shropshire
    Quote Originally Posted by family guy View Post
    Iv done it from the CD30 to The CD70 sat nav system .... well easy... no restrictions as long as the unit and screen are paired
    Iv put my own Aerial in ( non VX ) .... .... works a treat
    O ... the only thing was i needed to instal a washer sensor into the bottle... cos my car is base 1.8 model it was not already in
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    Quote Originally Posted by Steven T Davies-Moss View Post
    LOL or you can short that sensor to avoid warning message
    shropshire
    Quote Originally Posted by yysnet View Post
    Could have done.. that would b the easy option ... but i never take the easy option
    Jul 2010
    Scotland
    I don't either. Only reason is i check the car every week and top up the screen wash, so that sensor is not for me
    shropshire
    Id already got the sensor for pence and like makin up wiring looms so thought id do it properly. Now i can be lazy and wait for my car to tell me to open the bonnet
    Full Member Robsey's Avatar
    North East Cheshire
    24 Post(s)
    Trim : Energy
    Mileage : 131,000
    If you want Nav unit instructions, then go here
    http://www.opel-niedersachsen.de/pdf/CD70_DVD90NAVI.pdf
    Jul 2009
    salisbury
    Ive got the unit and screen fitted, the roof loom and aerial looks easy enough. Wot im nt sure of is the 2 short looms from the back of the unit, they dont look long enough, how do i route them to the body plug?, do i have 2 dismantle the whole centre console?
    North East Cheshire
    24 Post(s)
    Trim : Energy
    Mileage : 131,000
    All you should need to do, is
    1) Connect the head-unit to existing quadlock connector
    2) If you have the video lead, then just thread this through the back of the cage - up to behind the screen aperture, and plug in.
    3) Connect aerial plug for aerial
    4) Connect a GPS aerial to the GPS socket
    Job done.
    two short looms ?? sounds a little confusing - which ones.
    I had no spare looms, when converting CD30 to CD70 - just as described above.
    Only extra looms I may find would be a CDC40 DAB loom - not required on CD70, or an SOT lead which goes between headunit and quadlock connector, for interfacing a bluetooth or parrot unit.
    Do you have pictures of these two "small looms"?
    If they are for the modified aerial connection, then I would run them as directly as possible across the lower dash, until I get to the driver's kick panel.
    If you take the radio out, the heater panel (which just pulls out), and the lower drivers side trim panel below the steering wheel, then you should have enough access to feed any wires across.
  1. What a day retro fitting
    By marc vectra sri in forum Styling
    Last Post: 31st July 2012, 22:11
  2. retro fitting afl
    By andy.l in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2010, 14:42
  3. Retro fitting a CD70 upgrade from CD30
    Last Post: 21st March 2010, 22:46
vectra cdc70 retro
