Results 1 to 3 of 3
Thread: Loosing coolant on my 3.0DTi
    Regular Member Maurice's Avatar
    Nutterden (D)
    confused Loosing coolant on my 3.0DTi
    As the title says , i'm loosing coolant through the reservoir.
    At a "normal" drive (max 2500rpm) no problem , if i go over 2500rpm , like on a motorway drive , I start to loose coolant at the reservoirs overpressure hole. With a white cloud as a result...and a "low level" warning light after cooling down. The car has been to a workshop , they have taken the head of and drain't part of the engine's coolant. Could it
    be an airlock? Hope you experts have an answer..Otherwise it goes back to the garage again...
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Laufbuchsenabsenkung but before you take the car in for replacement engine let the engine run with the opened expansion tank. Should get cleared of all airlocks.
    Nutterden (D)
    Quote Originally Posted by Celes View Post
    Guess that that can't be possible...The car had no coolant problem
    before it went to the garage.And it has spend most of the time there , with only 500miles in between (has been back 3times ) . It's in the garage since this morning , so I hope it's something simple...Airlock or so.
    Thanks for your reply!
  1. Loosing Coolant
    By Coupe2T in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 10:03
  2. loosing engine coolant
    By pud wayman in forum Engine & Drivetrain
    Last Post: 25th March 2012, 10:16
  3. loosing engine coolant
    Last Post: 13th March 2012, 09:14
  4. Loosing coolant & foaming
    By si_hoss in forum Engine & Drivetrain
    Last Post: 27th January 2012, 14:12
  5. loosing coolant oh oh
    By toast in forum Engine & Drivetrain
    Last Post: 21st June 2010, 22:03
