Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: 150 miles in and problems already
    Kent
    Default 150 miles in and problems already
    Well 150 miles after I got the vectra 1.9cdti 2004 and it's started to have a few teething problems.
    Driving along and I can only describe it as the car would hesitate ever so slightly then revert back to normal, eventually the em light came on!
    The egr valve and mas was replaced in April this year and I had the car scanned and it came up with a couple of errors, I don't know the codes but 1 was to do with the glow plug circuit, the other was the accelerator sensor and the 3rd one the guy wasn't sure what it was something to do with the torque. He cleared them all and said to drive it until it happens again and he'll re scan it.
    Could the glow plug circuit or accelerator sensor cause the car to hesitate?
    My 2.2dti did this and it eventually cleared itself after a service but I think this was serviced 2k miles ago
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    I may be wrong, but as its a CDTI, the DPF maybe doing a regen, has it been fine since?
    Kent
    Thanks for the reply, what is a dpf?
    I pretty much went straight home but will give it a test run tomorrow
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    hi m8 your engine hesitation would generate a p0638 fault code .
    This is due to your throttle position sensor going faulty , what happens is as most people drive around only using upto only 20-25 % of the cars power the sensor gets worn at the low end and begins to give false readings to the ecu hence the hesitation.
    Glow plugs would generally give a p0380 fault code and is one of the more common codes generated by vectra,s with deisel engines .Nothing to worry about too much, it just meets one of the glow plugs is lazy and takes longer than the others to register.
    Kent
    Thanks for the response, where abouts is the throttle sensor? I assume down by the peddle, is it simple to change?
    I might have a look on eBay to see if I can pick one up
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by fattony View Post
    I'm having that issue. I wonder if there is something wring with the wiring/sensor. I'm getting the pedal unit replaced on Monday. Mines is a 2004 and had a misfire/hesitation for a long time until it came to a head two days ago - EM light and TC came on and the engine sat at 1,500rpm regardless of pedal position.
    Gazza4
    Kent
    Thanks gazza do you know how much that will cost?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Hang on m8 until I get my pedal replaced if it still does it on mine then I would suggest another route. I wonder if this is a new issue with the CDTI 150's as there are three 2004 models that have some form of throttle issue now. Wonder if it something that goes wrong after a certain time period.
    Gazza4
    Kent
    mine is the 120 m8
    Kent
    if it does solve your problem can you let me know how much you paid, I guess you cant just gt a sensor you have to buy the peddle?
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. 4 months and 10k miles with no major problems - V6CDTi
    By Celes in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2010, 22:58
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
