Results 1 to 10 of 19
Thread: Bonnet release cable.
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Default Bonnet release cable.
    Can the bonnet release cable be adjusted ?
    Mine seems to have gone slack and is becoming hit and miss on it opening !
    Sheffield
    Mines Completley Gone... The Lever has snapped off and i now have to use pliars to pull the cable to open my bonnet ....
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Quote Originally Posted by FIL 4822 View Post
    Yes. There is a bracket in on the slam panel. adjust it before its too late. I had major problems when mine went
    Regular Member Das's Avatar
    Turdsville
    36 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Thumbs up
    Quote Originally Posted by Keithy View Post
    Ah, mines slack too, job for tomorrow
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    phil were your bonnet cable appear,s on the bulkhead the retaining screw is the adjuster just release take up slack and resecure
    and still loving it
    Jan 2008
    Dundee
    seriously gents. get it done.
    Just loosen the bracket bolt and shift the cable until you get the tension
    Turdsville
    36 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Is it the cable you adjust or the cable sleeve keith?
    Jan 2008
    Dundee
    the sleeve mate. once you loosen the bracket. pull th cable and sleeve as far back to regain the tension. make sure you nip up the retaining bolt tight as the cable can slip
    Turdsville
    36 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Cheers, going to have a butchers the now.
    Turdsville
    36 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Job done. Tools required 8mm spanner or socket and pair or pliers. Loosen 8mm nut, grip cable sleeve and pull towards n/s of car. Sleeve should move and tighten. Re-tighten 8mm nut and before dropping the bonnet check the bonnet catch still moves in the cabin.
  1. bonnet release cable,,,AGAIN!!!!!
    By collyb in forum Bodywork & Interior
    Last Post: 25th June 2012, 08:49
  2. bonnet release cable
    By eminemme42 in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2012, 15:17
  3. Bonnet Release Cable Detatched
    By Landytim in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2010, 21:40
how to tighten bonnet release cable vectra c
hoq to take up cable slack of bonnet release system
vectra c bonnet cable adjustment
tighten vectra c bonnet cable
how to tighten corsa c bonnet cable
vectra c bonnet cable snapped
vectra bonnet release
bonnet cable snapped vauxhall vectra
corsa c bonnet release cable adjustment
vectra c bonnet release cable adjustment
