Results 1 to 10 of 21
Thread: MOT Fail Brake lines
    Regular Member fuzzbomUK's Avatar
    Jul 2008
    Milton Keynes
    Default MOT Fail Brake lines
    Hi all,
    As above Damn car failed MOT on corroded brake lines from front to rear.
    Would this be an item VX would stock or will it be a motorfactor and get them to make some up for me?
    I plan to do it myself, has anyone else had to do it and encountered any issues?
    Oct 2008
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Is it both of the front to rear ones? Where are they gone as the nearside one goes over the fuel tank and is a real ball ache. It's worth while going about buying a length of copper brake pipe and a flaring tool. The tool will pay for it's self eventually
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Why oh why are we still getting cars with unprotected brake lines these days When i was getting mine mot's the tester said there was the start of the signs of corrosion so while on the ramp he took a wire brush over them and them spray greased them to give them a bit more protection.
    Mar 2009
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    the lad who has a garge down the road had it on his vectra he got some rally brake pipe lines and used them
    Jul 2008
    Milton Keynes
    Yeah says both brake lines.
    dont say they go over the tank.. is it a tank out job or can you get the pipe past it?
    Oct 2008
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Nearside one deffo goes over the tank depending on where it's corroded i'd be tempted to join that one
    Ideally it's tank out but we managed with alot of messing to get mine done without taking the tank out. All 4 of mine have been replaced
    Jul 2008
    Milton Keynes
    I assume it was a roll of copper pipe and a flairing tool?
    Sorry just realised i posted in wrong section.
    Oct 2008
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Jul 2008
    Milton Keynes
    Awsome thanks ever so much for your help.
    Oct 2008
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Oh and the best tip for you, always make sure you put the union on before you flare the end
    Wouln't be the first time i've forgotten
  1. brake-lines.co.uk
    By MattVecVXR in forum Handling & Braking
    Last Post: 14th May 2012, 12:38
  2. Brake lines
    By dominic32 in forum Suspension, Wheels & Brakes
    Last Post: 16th October 2010, 23:31
  3. Brake lines - do they need to be declared?
    By cont1204 in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2010, 00:15
  4. braded brake lines
    By bigron1988 in forum Suspension, Wheels & Brakes
    Last Post: 6th April 2009, 22:37
  5. Braided brake lines.
    By 2ltrT in forum Handling & Braking
    Last Post: 20th February 2007, 19:47
